Home > Maintenance & Mods (L322) > Replace sunroof [glass part] seal
DavidP
Belgium 2006 Range Rover Vogue Td6 Bonatti Grey
Hi,
I am looking to renew the seal around the glass part of the sunroof. It's the rubber and a sort of suede[?] one.
Is it easier to remove the glass panel to do it? [6 torx screws], or is it possible in the tilt position?.
Also when doing it is it better to pre-heat or lubricate the rubber?.
Thanks in advance
Rgds
Post #547254 15th Mar 2020 8:55pm
kevinp
My seal has holes in it and it needs changing to. Any idea on price?
Post #548551 28th Mar 2020 3:17pm
Brandon318
United States 2009 Range Rover HSE 4.4 V8 Santorini Black
Re: Replace sunroof [glass part] seal
Unnecessary quote removed
Did you ever sort this out? Need to do this on mine too.
Post #717755 11th May 2025 4:08pm
kevinp
You have to buy the glass as well. Big Cry
Post #717759 11th May 2025 5:25pm
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
Did this every get sorted?
Bmw part number 54137344553 looks similar.
As the l322 was born BMW in its day they share same parts to the x5 and others. If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #722794 13th Aug 2025 4:03pm
