![]() | Home > In Car Electronics (L322) > L322 2010 android headunit rear screen function |
theJAFman Member Since: 02 Aug 2025 Location: London Posts: 87 ![]() ![]() ![]() |
I just found this on AliExpress:
exyjerome Member Since: 24 Mar 2025 Location: Hampshire Posts: 31 ![]() ![]() ![]() |
These Android head units aren’t fully compatible with the rear entertainment system. I installed one - rear screens didn’t work, and while the 4x4 info was available, it wasn’t the OEM version. If you have the 360 camera, accessing it on these units can also be tricky.
https://www.fullfatrr.com/forum/topic73930.html - this is the same as the UAD kit, just a fraction of the cost. It keeps the original unit and adds Carplay/Android auto using the OEM screen.
May have to consider it
landy95 Member Since: 04 Aug 2021 Location: West Midlands Posts: 86 ![]() ![]() ![]() |
Try this one.
Edwardcc Member Since: 21 Aug 2025 Location: Northwest Territories Posts: 7 ![]() ![]() ![]() |
I’ve looked into a few of those Android head units for the L322. The main thing to keep in mind is that the rear entertainment system in these cars is usually tied into the original factory head unit. That means if you pull the OE screen/brain out, the rear headrest screens often won’t function independently unless the new unit has proper integration.
Thanks mate
