![]() | Home > Maintenance & Mods (L405) > RED DPF restricted performance half way down France |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8090 ![]() ![]() ![]() |
Any error codes ?
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3304 ![]() ![]() ![]() |
Have you checked for any poped hoses on the intake? A failed throttle plate control would also give the delayed shutdown and not throw a specific code. It’s easy to check by removing the plastic intake elbow and seeing if the plate is loose. Also an easy fix by replacing the throttle body. 2012 TDV8 Vogue (L322) |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3862 ![]() ![]() ![]() |
Simple 5 minute job, check the MAPT sensor for being blocked with dirty oily crud.
911r44 Member Since: 30 Oct 2022 Location: Nottingham Posts: 15 ![]() ![]() |
Thank you all for your thoughts, to update.
Some figures |
If you do a Forced Regen, then the Red DPF full warning will clear automatically once the soot reading drops below 27g ish.
Definitely DO NOT do a ‘DPF changed’ action. Oil and soot buildup is totally normal. The issue with the O2 sensor should be investigated as this could be causing regeneration to not happen and other engine fuel management issues. 2012 TDV8 Vogue (L322) |
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1412 ![]() ![]() |
