Home > In Car Electronics (L322) > Bluetooth upgrade
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
I replaced the Nokia unit on my 2006 facelift car with the same later unit as you.
It all worked fine on our car with my Android phone finding the LANDROVER Bluetooth signal immediately.
I'm not sure if there are any diagnostics available that will check if the BT unit is working - otherwise it might be a case of swopping yours with a known working unit to check if the problem is the car or the unit.
PS Where in the Midlands are you ? I'm just South of Solihull Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #692927 18th May 2024 10:58pm
22Auto
United Kingdom 2005 Range Rover HSE Td6 Giverny Green
Hi Paul thanks for the prompt reply.
I'm in the Dudley area but pop over to the Solihull area quite a lot to visit friends etc. I'm not aware of any easy diagnostics to check the module either so am just relying on the sellers description of it being in 'excellent working condition'.
Will check my wiring connections again and give it another go in the meantime.
Thank you
Post #692953 19th May 2024 11:14am
22Auto
Just thought I'd give an update on the status of my issue now it's working OK.
I re checked my wiring it all looked OK, with 12V going to the new module. When the new module is connected up the rest of the system features work, such as the radio CD Nav etc, and when the electrical connection is removed nothing does, so I took it that the new module was being powered up OK but there was still no sign of Bluetooth activity.
Whilst in 'clutching at straws mode' I decided to resort to the old failsafe of doing a battery reset, so disconnected the vehicle battery for about 20mins or so, just in case the whole system needed to boot up from scratch with the new module fitted in order to recognise it, or something.
Subsequently when scanning for Bluetooth on my phone the Land Rover module was visible, and after pairing the phone the vehicle screen populated with my address book etc and it is possible to make calls etc. Happy days.
Thank you Paul for your support and confirmation that the new unit I had should work successfully on my L322.
Now to get the Venture Cam working again......
Post #693041 20th May 2024 6:52pm
AlvaroDiasRodrigues
Portugal
Did this mod today and I’m glad to have Bluetooth on my recently bought 2005 Vogue TD6.
Bluetooth now works flawlessly after replacing the Nokia module, that was dead as a dodo.
Just one thing that made me thinking: why does the plug of the Nokia module has so much wires while the new module only needs positive and negative wires?
Thanks!
Post #722386 5th Aug 2025 10:41pm
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
well, you seam to have sorted it, so i thought i would give it a go.
this is way above my skill level but with the information available on these pages, why not.
i have ordered the said part from the UK, hope its a good one.
before i start, i would like to ask and i have asked this before, could you tell me what these parts are and what they are for
 RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #722449 7th Aug 2025 2:38am
knares
the part arrived yesterday
i fitted it as instructed and my phone is seeing the land rover
now its asking for a pin number
where do i get that from ???
i cant believe how easy it has been to get this far
thanks RR 2005 4.4 petrol
Post #723073 19th Aug 2025 9:26am
mjdronfield
I believe it’s 2121.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #723075 19th Aug 2025 10:15am
knares
mjdronfield
BRILLIANT JUST BRILLIANT
Post #723080 19th Aug 2025 11:03am
