![]() | Home > Technical (L405) > Rotary Gear Selector wont rise 'N' flashing |
lambo911 Member Since: 13 Jan 2022 Location: St Albans Posts: 101 ![]() ![]() ![]() |
Sounds like you need a new controller. Mine failed, would rise but I couldn't turn it out of neutral.
Spridget Member Since: 09 Dec 2023 Location: Northumberland Posts: 203 ![]() ![]() ![]() |
I'm sure there is a thread on this somewhere. There's an interlock that can be taped back to stop it engaging as a temporary fix. Sorry I can't be more specific but it's there somewhere. |
Ukandrewf Member Since: 29 May 2013 Location: South bucks Posts: 251 ![]() ![]() ![]() |
thanks for the tip will go an search --
RRV8SC Member Since: 02 Oct 2021 Location: SW London Posts: 199 ![]() ![]() ![]() |
goldeneye32 Member Since: 10 Jan 2024 Location: Hampshire Posts: 106 ![]() ![]() ![]() |
Mine went a few months back, it can be removed, sent away, repaired, tested and sent back, don't know how but they offer a lifetime warranty with it (probably 10 years in car terms).
did you remove it yourself and send it away for repair?
Err No, garage removed it sent it away and then refitted it, I had to have the car recovered somewhere, and as I didn't know exactly what was wrong with it, it would've been stuck on my drive. |
Crasher242 Member Since: 07 Mar 2019 Location: Warwickshire Posts: 142 ![]() ![]() ![]() |
My unit failed too (there is a thread about it somewhere here). Although my failure was that it would not allow the drive selector to be rotated (it still would rise/fall ok).
Just a thought - have you managed to read any fault codes?
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822 ![]() ![]() ![]() |
IIRC that red strap is to put the transmission in neutral if the gear selector fails, so you can move it onto a recovery truck, don't think it does much for the parking brake, you can put that in service mode with an IID or similar... |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1557 ![]() ![]() |
The common failure of these seems to be the solenoid section not retracting back well enough. Whether it's the solenoid or the power circuit driving it.
