Home > Maintenance & Mods (L405) > Right, who scared my L405, its wet itself …
fisha
Either that it’s got scared hearing my wife talking about wanting a Defender … so wet itself.
Sigh. Rolling Eyes Laughing
So dampers ordered, I’ve read on here that it can be down without seats out …I presume just from the boot side to get access , many tried it that way ? V8 or else ...
Post #723303 23rd Aug 2025 12:38pm
I replaced mine last seek. No need to take the seats out but it’s tricky. There’s a stabiliser bar that needs to be removed to get to 2 of the top nuts as well as the boot liner and the associated trims.
If you need to know more, ping me a message. Got - 2017 SDV8 Autobiography in Loire Blue
Post #723307 23rd Aug 2025 1:40pm
fisha
thank you.
I watched the video on raymiesgarage on youtube about it which showed the seats coming out, but on re-searching also found the Lucky 8 video below
where they've accessed the bolts without the seats and without the strut bars coming off too. So that might be a first attempt that way. V8 or else ...
Post #723308 23rd Aug 2025 2:18pm
Yeah. I watched Raymies video first but I can’t see how you can get the top shocker bolts off without taking off the strut bars off, well at least 2 of them, but I wish you the best of luck! Got - 2017 SDV8 Autobiography in Loire Blue
Post #723310 23rd Aug 2025 3:05pm
fisha
The chap in the lucky8 video ( at 3mins mark ) says put the socket fully on the nut first, then put the square socket extension bar into the socket at an angle afterwards as a lot of the modern socket bars can be run at slight angles if you dont fully insert them.
I'll report back when I try it ! V8 or else ...
Post #723311 23rd Aug 2025 3:23pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
Make sure its not the brake lines, thats what mine did and it was the brake line
Post #723312 23rd Aug 2025 3:45pm
fisha
For a fleeting moment I thought, oh ya dancer … if it’s brakes that’ll be a lot cheaper. Raced outside, check and guess what …
It’s the not the brakes Big Cry
Ah well V8 or else ...
Post #723369 24th Aug 2025 2:51pm
They would cost you as much Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #723376 24th Aug 2025 7:05pm
Mikey
At least it's not ARC pipes Wink
Post #723381 24th Aug 2025 8:55pm
fisha
100% yes.
When I first noticed it, the first thing I thought was " well, whatever that is, at least it cant be the ARC pipes " V8 or else ...
Post #723382 24th Aug 2025 9:17pm
Dixy
2016 Range Rover Vogue SDV8 Loire Blue
This is good timing as mine needs doing as well.
Where did you get the dampers from and which ones did you buy, did you also replace all the nots and bolts.
Some photos as you go along would also be great. letters not necessarily in the right order
Post #723386 25th Aug 2025 7:28am
fisha
The dunlop ones from maltings. I dont have experience/knowledge of the aerosus ones which show up as cheaper, but the relative smaller difference for dunlop ones sat a bit better in my mind.
Bolts ... I've not read it for the dampers, the workshop manual normally says to replace bolts. If I'm brutally honest, I could see myself re-using them.
Yes, I'll take some photos and stick on here. V8 or else ...
Post #723390 25th Aug 2025 9:16am
