![]() | Home > Maintenance & Mods (L405) > Right, who scared my L405, its wet itself … |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6829 ![]() ![]() ![]() |
I replaced mine last seek. No need to take the seats out but it’s tricky. There’s a stabiliser bar that needs to be removed to get to 2 of the top nuts as well as the boot liner and the associated trims.
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1517 ![]() ![]() |
thank you.
Yeah. I watched Raymies video first but I can’t see how you can get the top shocker bolts off without taking off the strut bars off, well at least 2 of them, but I wish you the best of luck! Got - 2017 SDV8 Autobiography in Loire Blue
The chap in the lucky8 video ( at 3mins mark ) says put the socket fully on the nut first, then put the square socket extension bar into the socket at an angle afterwards as a lot of the modern socket bars can be run at slight angles if you dont fully insert them.
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1513 ![]() ![]() ![]() |
Make sure its not the brake lines, thats what mine did and it was the brake line |
For a fleeting moment I thought, oh ya dancer … if it’s brakes that’ll be a lot cheaper. Raced outside, check and guess what …
They would cost you as much |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1852 ![]() ![]() |
At least it's not ARC pipes |
100% yes.
Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 1116 ![]() ![]() |
This is good timing as mine needs doing as well.
The dunlop ones from maltings. I dont have experience/knowledge of the aerosus ones which show up as cheaper, but the relative smaller difference for dunlop ones sat a bit better in my mind.
