Home > Wheels & Tyres > Spare Wheels
Fraser1307
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
Spare Wheels
I recently bought a set of spare wheels which I was told came from an L322 but I tried to fit them today and my wheel nuts wouldn’t go through the hole on the wheels.
Any suggestions of whether I could get a narrower set of wheel nuts and from where?
Post #723325 23rd Aug 2025 9:31pm
PeteT80
Sounds like you’ve got the earlier type of wheels from a pre 2006 L322. The wheel nuts are a smaller diameter.
Post #723326 23rd Aug 2025 9:43pm
Fraser1307
Thanks for your reply, so would I not be able to get wheel nuts to fit?
Post #723327 23rd Aug 2025 9:45pm
there are 2 types of wheels and nuts for the L322,
Post #723328 23rd Aug 2025 9:47pm
Fraser1307
Thanks.
Would the 2005 nuts still the the bolts on a 2011 model?
Post #723329 23rd Aug 2025 9:50pm
2005 onwards wheels need bigger nuts....pre 2005 wheels need the smaller nuts..
you can fit 2005 onwards wheels on the earlier L322 with the correct nuts. ... - .- -.
Post #723331 23rd Aug 2025 9:57pm
Fraser1307
I’m really sorry, I’m new to all this.
So am I able to get 2005 wheel nuts to use on a 2011 model?
I’m really hopeful that I’ll be able to make use of the spare wheels that I bought.
Post #723342 24th Aug 2025 7:31am
If the wheels you have are genuine LR wheels then yes the earlier wheel nuts will fit your car. Sets are available from eBay or any LR outlet.
Post #723343 24th Aug 2025 7:51am
Fraser1307
Thanks very much for your reply, I really appreciate it.
Owning the car has been a great learning journey so far, yesterday I replaced brake lines, callipers, discs and pads which was good fun!
Sorry in advance for more silly questions as I learn what I’m doing.
Post #723344 24th Aug 2025 7:55am
Baltic Blue
It’s doubtful that any earlier wheels will fit on a 2011 because they won’t fit over the larger disc brake calipers.
Post #723345 24th Aug 2025 7:56am
Fraser1307
The wheels themselves fitted fine, it was the nuts that wouldn’t fit through the holes on the wheel.
Post #723346 24th Aug 2025 7:58am
can you show us which wheels you actually bought.. ... - .- -.
Post #723352 24th Aug 2025 10:03am
