Home > Technical (L405) > Over sensitive parking sensors….
JW911
Still getting used to my new 405. It has the driver assistance pack, self parking (haven’t tried that yet) and various other tech.
However, one thing I have noticed is that if I go to full steering lock to the right, it seems to detect its own (right) front wheel and goes bananas. Can the sensors be recalibrated? 2021 3.0 P400 Vogue
2012 4.4 TDV8 Westminster - gone!
2007 3.6 TDV8 Vogue - gone!
2003 4.4 V8 HSE (LPG) - gone!
2018 F-Pace 25t Portfolio
1974 LR Series III Lightweight FFR
2014 BMW 640i Gran Coupe
Post #712651 23rd Feb 2025 10:04pm
JW911
Don’t suppose anyone has an answer to this please?
I don’t want to replace a parking sensor unless I know for sure it’s definitely faulty but quite frankly this is making me want to get rid of the car. Turning left is fine, turning right, the parking sensors go bonkers. I’ve experimented by covering part of and ultimately all of the sensor (the one just forward of the offside front wheel) with duck tape and it makes zero difference. 2021 3.0 P400 Vogue
Post #723375 24th Aug 2025 6:45pm
Is it sitting properly? Got - 2017 SDV8 Autobiography in Loire Blue
Post #723378 24th Aug 2025 7:18pm
JW911
It appears to be. I undid the wheel arch liner and had a jiggle. All seemed fine. 2021 3.0 P400 Vogue
Post #723379 24th Aug 2025 7:34pm
Gremlin500
Re: Over sensitive parking sensors….
Rolling with laughter Rolling with laughter Rolling with laughter V6 Vogue - “Less is More” - less to go wrong!
Post #723383 24th Aug 2025 11:13pm
JW911
I bet he had the same problem…. 2021 3.0 P400 Vogue
Post #723400 25th Aug 2025 12:44pm
CS
No experience of the issue you describe, but I have had numerous false positives when the sensor faces corrode and delaminate, they then come on when eg reversing into an empty space. So it is possible that the car is "aware" that it is turning into the area covered by the sensor in question and the delamination then causes the false positive signal, rather than that it is "seeing" the wheel. Sometimes a piece of leaf or other debris stuck to the sensor face can cause a false positive too.
In my case the corroded sensors were replaced (some have been replaced more than once, the quality on 405s seems inferior to those used in 322 for example) and that solved it. I now make a point of washing them off with cold water every time they get covered with salt, that has been helpful, but has not eliminated the issue. Only Range Rovers since 1988
Post #723411 25th Aug 2025 2:49pm
Rob99
That'll polish out with a bit of T-cut Rolling with laughter Rolling with laughter 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #723413 25th Aug 2025 3:03pm
JW911
Thanks. That sounds pretty plausible.
Anyone know a good supplier of sensors who doesn’t charge £1M? 2021 3.0 P400 Vogue
Post #723441 25th Aug 2025 9:18pm
CS
Mine were done under the LR 6yr corrosion warranty, the second time there may have been an element of goodwill arranged by the dealer as the problem had recurred in only about a year. If your car is a 2021 then maybe you could get it sorted that way ie FOC? Only Range Rovers since 1988
Post #723444 25th Aug 2025 9:43pm
Sensors will be 18MY onwards if your looking for replacements? 12-18 won't work or indeed fit... Thumbs Up
Post #723450 26th Aug 2025 12:14am
JW911
Thanks all. 2021 3.0 P400 Vogue
Post #723468 26th Aug 2025 1:42pm
