Home > Maintenance & Mods (L322) > Rear washer not working
JonnyCJ
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Sumatra Black
Hi all - I’ve swapped over the washer nozzle for one of the fancy eBay twin nozzles.
The washer never worked as the jets and hose through the motor were gunked up.
Trying the washer for the first time, there was a very brief dribble of water and then nothing. I thought the jets may be blocked, but they’re clear.
I assume the water flows from the same washer bottle that does the fronts (which work fine), so looking for a little bit of guidance please on where to start troubleshooting.
Cheers
Jonny
Post #723396 25th Aug 2025 11:21am
JCW
My guess would be the one-way valve situated in the supply pipe behind the tailgate trim. Jonathan
2010 L322 5.0 SC Autobiography Black
2007 Defender 90 XS Hardtop
Post #723397 25th Aug 2025 11:29am
Baltic Blue
Take the pipe off the non- return valve and try again.
If you get water then pump is OK and non return valve valve is blocked.
Post #723398 25th Aug 2025 11:33am
JonnyCJ
There’s actually no water coming from before the non return valve. All fuses seem ok as well.
Post #723404 25th Aug 2025 12:43pm
pcourtney
very common - more info here
https://www.fullfatrr.com/forum/topic66546...turn+valve
Post #723407 25th Aug 2025 1:06pm
JonnyCJ
Problem solved - hands up who selected the “rear washer and wiper won’t work with the tailgate open” option.
All sorted, getting a good squirt through the exposed nipple. I’m re-painting the wiper arm as I can’t get a new one in the right size anywhere for decent money.
Might as well treat myself to a new wiper blade as well seeing as I’ve made progress !
Incidentally, the one way valve won’t work if you try and blow through it. It’s almost as though it’s blocked, when it isn’t. It just needs sufficient pressure to operate the rubber diaphragm inside, so before thinking yours is blocked and buying a new one, be aware that you can strip it down by separating the top cap with the arrow on, from the main body with a Stanley blade.
Post #723408 25th Aug 2025 1:23pm
pcourtney
well done Sir Smile
I bought one last year off ebay for £1.50 , NRV 4mm, seems fine, I think it was for an aquarium or pond
Post #723409 25th Aug 2025 1:33pm
Speedbird209
United Kingdom 2003 Range Rover Vogue Td6 Alveston Red
I found a genuine rear wiper on eBay June and thought too good to be true as it was £25 or best offer and they accepted £20. Arrived four days later and it was a genuine unopened LR012046LR. Fitted like a glove.
If you haven't started your repaint and want the seller's details feel free to let me know as you never know, they may have another laying about.
Post #723869 3rd Sep 2025 3:09pm
JonnyCJ
Many thanks - arm all painted up I’m afraid, but appreciate the info.
Cheers
Jonny
Post #723872 3rd Sep 2025 3:28pm
