![]() | Home > Off Topic - Other Cars > XJ8 ZF5HP24 Sonnax or TransGo |
SpannersNK Member Since: 25 Aug 2025 Location: Kent Posts: 4 ![]() ![]() |
Just realised I've put this in the wrong forum guessing it should be L322 technical. Can I move it myself? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874 ![]() ![]() |
this is a range rover forum regardless whether the engine 'might' be similar ..
Hi, Yes I realise that but the ZF gearbox is the same model as used on the 332 and you have many threads relating to the repair of it specifically the regulator valve hence my post. I actually got referred here after reading RRPhill's post that was quoted on the Jag forum. Somebody on there mentioned they had used him in the past and he could be contacted here.
