Home > Maintenance & Mods (L405) > Just been Bodsy'd
-L-
United Kingdom 2011 Range Rover Vogue TDV8 Bonatti Grey
Just been Bodsy'd
Bodsy has been this morning and changed the transmission fluids.
Jolly nice bloke and all that, but yet to drive the car... Hoping I'll notice the difference on the drive home this evening!
Post #723865 3rd Sep 2025 3:39pm
sullivj
United Kingdom 2014 Range Rover Autobiography SDV8 Santorini Black
Could you give some more details of Bodsy please...?
Post #723868 3rd Sep 2025 4:02pm
Gremlin500
Just search “Bodsy” using search facility above?
My WIFE noticed a difference the next day, without even being prompted Shocked Laughing V6 Vogue - “Less is More” - less to go wrong!
Post #723874 3rd Sep 2025 4:51pm
sullivj
Will do - thanks.
Post #723878 3rd Sep 2025 5:01pm
mjdronfield
Can be a bit difficult to get hold of. Texting might work best.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #723879 3rd Sep 2025 5:12pm
-L-
Updates by Bodsy - https://www.facebook.com/UpdatesByBodsy/?locale=en_GB
Other than a few reports of communication issues, he seems to be very widely respected and comes recommended by various people, including not on this forum people.
I had no problem getting hold of him and agreeing a date. In fact, I was a bit surprised he was able to come round within a fortnight of my original enquiry! (which suited perfectly as I was away anyway).
Just drove home and the old girl is definitely smoother.
£560 for all transmissions fluids = Good peace of mind
Post #723880 3rd Sep 2025 5:19pm
mjdronfield
Think that was what I paid in March 2024. Top bloke and service.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #723885 3rd Sep 2025 7:47pm
DrRob
Bodsy is a top guy and his work is legendary.
Best to text him on 07770 638023 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #723897 3rd Sep 2025 9:08pm
Gremlin500
Took a little time to organise, but then he did come all the way up to Newcastle on Tyne to do ours to be fair, which I was very grateful for, he’s a busy guy. A proper gent, even sprayed a bit of Lanoguard on several rusty bolts for me while he was under there for a few cups of coffee. Thought the car was OK to drive beforehand, but it’s smooth as silk now, well worth doing bit of preventive maintenance. I tried to just let him get on with it as much as possible, I don’t like folks standing over me when I work. He did a great job, and not a drop split on my driveway, so my coffee must be THAT good! Laughing
So its 5 stars & a “Recommended” from Gremlin Thumbs Up V6 Vogue - “Less is More” - less to go wrong!
Post #723904 3rd Sep 2025 10:26pm
CerebralThunder
What is it he does exactly?
I see transmission fluids, silky smooth driving and some costs mentioned but wondered what he does to achieve this?
Thanks for any help and sorry for being so thick. 2021 L405 Range Rover 'Fifty' D350
Post #723972 4th Sep 2025 10:24pm
mjdronfield
Gearbox, front differential, rear differential and transfer box oil change.
He uses a megaflush machine to do the gearbox.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #723973 4th Sep 2025 10:30pm
Gremlin500
It’s something which really needs doing every 50K-60K miles to avoid future VERY expensive gearbox repairs or even a 5-figure replacement, -which is denied by JLR as being necessary, because they would love to charge you for a new auto box, Sir.
It’s not something the average owner can do as it needs specialist equipment. If you drain and refill the transmission yourself, you leave a good porportion maybe 25% of old dirty oil behind. The Megaflush process removes 99% of the old oil and replaces with new, so is much more efficient.
Think of it as liquid insurance, same as 6-monthly oil changes for your engine.
IMHO, it’s a no-brainer. V6 Vogue - “Less is More” - less to go wrong!
Post #723974 4th Sep 2025 11:18pm
CerebralThunder
Thanks for the replies.
I'm genuinely interested in Bodsy's process, as I recently had engine oil and filter replaced, both diff oils, transfer box fluid and gearbox megaflushed, but the car is driving worse than before the work. It seems to be hunting for gears and changing between them quite harshly. As you know, it's a very expensive process.
They have very kindly agreed for me to take it back to them so they can have a look into it, but I wondered if there was a bodsy secret ingredient? 2021 L405 Range Rover 'Fifty' D350
Post #723976 4th Sep 2025 11:39pm
Gremlin500
The “secret ingredient” is probably doing the job properly and with care. It takes a long time, waiting for the gearbox to come up to temperature at each stage before continuing, it’s not something you can rush or cut corners, it takes around 2 hours for just the transmission box alone.
It also takes a few days of driving for the reset gearbox to readapt itself to your driving style, and you need to drive sympathetically during the first few hundred miles, which is what Ian told me. V6 Vogue - “Less is More” - less to go wrong!
Post #723989 5th Sep 2025 10:13am
fisha
My understanding is that the gearbox learns under light acceleration where the revs are kept below 2000rpm, and also when you let it coast down through the gears.
On the 6spd ( and I’ll apply the assumption that the 8 spd is likely similar) the procedure was to go from standstill, accelerate keeping it under 2000rpm pro to at least 4th and hold the speed steady at about 50mph for a short period, then let your foot off and allow the car to coast back down to almost a stop at which point you apply the brakes and stop the car and hold it for a short period. Those conditions are when it learns the bite points and adapts. It may take a few goes to get full adaptation. V8 or else ...
Post #723995 5th Sep 2025 10:56am
