![]() | Home > Maintenance & Mods (L405) > Replace brake caliper screws? |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1880 ![]() ![]() |
The original L320 carrier bolts were never single use, and they were torqued to 275Nm
jensputzier Member Since: 18 Aug 2024 Location: Leichlingen Posts: 3 ![]() ![]() ![]() |
The difference is that after torqueing them you turn them 60 degrees further which makes me believe that they are expansion screws. Which normally have to be replaced. |
RRYorks Member Since: 13 Jan 2020 Location: Yorkshire Posts: 53 ![]() ![]() ![]() |
Workshop manual says replace 2018 4.4 TDV8 |
zenman63 Member Since: 14 Nov 2021 Location: Warwickshire Posts: 256 ![]() ![]() ![]() |
Yes single use stretch bolts same on the rears. |
