Home > Maintenance & Mods (L405) > Replace brake caliper screws?
jensputzier
Germany 2019 Range Rover Autobiography 5.0 SC V8 Loire Blue
I started to put new brake discs and pad on my 2020 5.0SC. Got 380mm Brembo discs and ceramic pads and the installation kit with all the pins etc.
The only things that were not included were the four screws that hold the brake calipers. As they are supposed to be tightened with 133Nm and 60 degrees I take that I have to use new ones. Correct?
Post #724099 7th Sep 2025 12:30pm
Mikey
The original L320 carrier bolts were never single use, and they were torqued to 275Nm
I wouldn't worry about replacing them Thumbs Up
Post #724101 7th Sep 2025 1:21pm
jensputzier
The difference is that after torqueing them you turn them 60 degrees further which makes me believe that they are expansion screws. Which normally have to be replaced.
Post #724106 7th Sep 2025 2:18pm
RRYorks
United Kingdom 2018 Range Rover SVAutobiography SDV8 Loire Blue
Workshop manual says replace 2018 4.4 TDV8
Post #724117 7th Sep 2025 4:25pm
zenman63
England 2018 Range Rover SVAutobiography 5.0 SC V8 Firenze Red
Yes single use stretch bolts same on the rears.
Post #724123 7th Sep 2025 4:54pm
