|  | Home > Maintenance & Mods (L322) > Diffs, transfer case & tranny oil service |
| lschwarcz Member Since: 18 May 2019 Location: Hillsboro, OR, USA Posts: 276      | OK, I won't tell you   | ||
|  9th Sep 2025 4:37pm |
| Sql Member Since: 27 Jun 2015 Location: Poland Posts: 258      | Jesus today I literally picked up my car after replacing my fluids by YOUR list. So I now have them in backwards 🤦♂️ 12 4.4 TDV8 Vogue
|  9th Sep 2025 5:51pm |
| Sql Member Since: 27 Jun 2015 Location: Poland Posts: 258      | Can someone PLEASE confirm 100% what diff fluids I need for 2012 4.4 TDV8 with LOCKING rear diff? 12 4.4 TDV8 Vogue
|  9th Sep 2025 5:53pm |
| RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1044    | Front – Castrol SAF-XO 75W/90. Land Rover part no. TYK500010 or LRN7591. Service fill = 0.75 litres
|  9th Sep 2025 8:20pm |
| Sql Member Since: 27 Jun 2015 Location: Poland Posts: 258      | Thank you Phil! 12 4.4 TDV8 Vogue
|  10th Sep 2025 7:26pm |
 Sql, sorry about my error in posting. I would suggest double checking everything you read on this or any forum out there. When researching the fluids I found a lot of conflicting data but by checking many sources including the factory service manual and Land Rover dealer websites for the right fluids only then did I finally buy and use them. All information posted on public forums is. "use at your own risk." It's unfortunate but people do make mistakes and I'm no exception. When reading this thread and you see I have conflicting information (reversing the part numbers), the fact that your car is a different year, different generation of the L322 with even a different engine should be enough to make extra sure the information is correct and applies to your car. All car companies change specs and hardware and even if I had not posted the incorrect information I would have suggested you be very careful about applying this info to your car. Hopefully you now have the correct information and are successful with your servicing! In the future I'll try to be more careful when posting information here. Good luck! Larry. 2009 Range Rover L322 Autobiography Bournville/Ivory Save lives, give blood. | ||
|  11th Sep 2025 3:40pm |
| Sql Member Since: 27 Jun 2015 Location: Poland Posts: 258      | Yeah, I found it crazy confusing when reading a bunch of writeups on those diff oils. Castrol this. Castrol that, LR number this or that. Also open diff this and electronic lsd that. When I found your post consisting of simply two part numbers and knowing you had facelift electronic diff car I just copied that and texted to my mechanic.
|  11th Sep 2025 3:46pm |
| lschwarcz Member Since: 18 May 2019 Location: Hillsboro, OR, USA Posts: 276      | Hi Sql,
|  11th Sep 2025 4:00pm |
| Sql Member Since: 27 Jun 2015 Location: Poland Posts: 258      | Sure, I know, I have 2/3 of them, a 2007 and a 2012. 12 4.4 TDV8 Vogue
|  11th Sep 2025 6:22pm |
| Posting Rules
 . But, it looks like I did get them backwards!
