![]() | Home > Maintenance & Mods (L322) > 4.4 TDV8 EGR and DPF removal |
| steve2347 Member Since: 09 Jan 2025 Location: Reading Posts: 42
Here's a video
| Aviator Member Since: 11 May 2025 Location: Berkshire Posts: 21
Mine sounds much the same as that |
Interesting. Thanks for confirming. If it's not causing any harm then I'll ignore it |
Just wondering if you have any updates on this? Things have changed quite a lot in my case so I'll share a proper update once I have some time. |
| matthews Member Since: 09 Aug 2016 Location: Leeds Posts: 112
Having spoken to a few people round my neck of the woods re mapping and not having the confidence to use them (i run a small classic car and older LR specialist garage so when i get told we just turn it off and you won't get a warning light on i walk away) anyway spoke briefly to a friend and owner of a larger outfit that deals with more modern LR stuff it appears that one of the trusted LR tuners(4.4tdv8 not really listed on his webpage) can map it out properly and changes various other parameters in the map to compensate for the lack of egr , i'm going to be going down this route in a couple of weeks (friend is on holiday at moment) and will report back once tested , by all acounts the trusted tuner i n question had one for quite a while and did plenty of work sorting it all out properly , most of his egr mapouts go to Belgium and Australia by all accounts , I've been to the co in question about 15 years ago and the mild remap he did on my D2 was exactly as i asked and after 15 years and another 150k miles on a 90k engine is still running clean and sweet (yes i still have old faithfull waiting for a new skeleton but still runs sweet as a nut), hopefully by back end of month i'll be able to report back with a glowing report.
Thanks, appreciate the update. Very interested to hear your outcome.
| JayGee Member Since: 27 Jul 2021 Location: London Posts: 3404
Difference in comanded and actual EGR value is I think normal as mine is the same. Likley it's self calibrating based on feedback from the O2 sensor measuring actual EGR content. Also if you are getting 18psi on an intake pressure test then no way you would have even a small EGR leak as it would not be holding that kind of pressure and blowing a lot of smoke from the tailpipe. The loss of mpg is a cause for concern but not EGR related IMO and if it's over fueling it will create more soot. 2012 TDV8 Vogue (L322) |
| mgrover Member Since: 03 May 2020 Location: Leeds Posts: 434
be interesting to hear back from this cause am in Leeds and may do mine as well tbh Its actually a sport Not anymore, 4.4 TDV8 now |
Managed to get out for a good motorway run and it actively regened down to 2.5g soot mass.
| Fantom L322 Member Since: 26 Jul 2024 Location: Melbourne Posts: 4
Hi guys
| All times are GMT |
