![]() | Home > In Car Electronics (L405) > No Dab signal when switching on car. Fine when parked |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35861 ![]() ![]() |
welcome to the forum..
Dandrover Member Since: 10 Sep 2025 Location: Scotland Posts: 21 ![]() ![]() ![]() |
Thanks for the reply.
if you've disconnected the plug that goes into the dashcam and you still have the problem then its not the dashcam...
I'd seen a post somewhere else where somebody said that disconnecting it from the camera only may not work and it should really be done at the fuse as well. That didn't make a lot of sense right enough because if it's disconnected at one end then surely that would be enough! |
jimmie Member Since: 19 Jul 2014 Location: Warsaw Posts: 201 ![]() ![]() ![]() |
I had similar issue with cheap phone charger. Some not filtered dc/dc converter will kill dab / radio. |
hmallett Member Since: 21 Jan 2024 Location: Mid-Wales Posts: 154 ![]() ![]() ![]() |
When I bought my car, it had a non-genuine rear light fitted, and the DAB reception was terrible. I had read that non-genuine lights could have this effect, and I changed my light, and the DAB reception improved. |
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1434 ![]() ![]() |
The aerials are in the tailgate (does it have rear dash cam feeds?) and aerial cables will probably go over head to entertainment system. Any cables run close to aerial will cause interference.
goldeneye32 Member Since: 10 Jan 2024 Location: Hampshire Posts: 106 ![]() ![]() ![]() |
This won't solve your issue, but when I listen to DAB, and i put the rear heated screen on, no DAB. |
That's interesting, I'm pretty sure I found a receipt for a rear light from a few years ago so I wonder if it was non-genuine and that's what's causing the problem? I actually managed to find 2, (but garbage) channels it would pick up today whilst running the car, so it doesn't appear it flat out won't work when the ignition is on, but functionality is greatly reduced. Totally fine when ignition off. I've bought a battery tester as well to check that, so thanks for the previous suggestion re battery condition. |
