![]() | Home > In Car Electronics (L322) > L322 touch screen with phantom/random screen inputs! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35837 ![]() ![]() |
check that boot area for moisture first ... - .- -.
Turbostars36 Member Since: 07 Aug 2025 Location: Reading Posts: 4 ![]() ![]() ![]() |
Thank you. No moisture or evidence of corrosion on modules in boot but I noted the rear tailgate rubber seals were replaced before I got it. |
If it is not the touchscreen might it be something else? I’m thinking about replacing the head unit but concerned the problem could be elsewhere or is this unlikely based on the symptoms? |
Edwardcc Member Since: 21 Aug 2025 Location: Northwest Territories Posts: 7 ![]() ![]() ![]() |
That definitely sounds like the classic “phantom touch” issue. On the L322 it’s usually one of two things:
Thank you Edward, your response is very thorough and knowledgeable, I really appreciate you taking the time, awesome!
