Home > Maintenance & Mods (L405) > Right, who scared my L405, its wet itself …
fisha
Oops… no message. V8 or else ...
Post #723724 31st Aug 2025 11:05pm
Dixy
2016 Range Rover Vogue SDV8 Loire Blue
Thanks Fisha, that is realy helpful.
As yours is an SDV8 like mine which of the Maltings 4x4 Dunlop shock absorbers did you get. letters not necessarily in the right order
Post #724064 6th Sep 2025 1:52pm
fisha
Just looked back at the order:
Dunlop Right Hand Rear Shock Absorber for Range Rover L405 - LR034266
Dunlop Left Hand Rear Shock Absorber for Range Rover L405 - LR034271
They both plugged in just fine, and zero errors or need to reset anything.
Only thing that annoys me was that my car always wants to self level downwards when jacked*, so when it came to removing the damper out, I had to faff with jacking the car to get enough clearance back.
Its blooming infuriating ... I'll need to figure out a solution, cause all the normal options of leave a door open etc just doesn't stop it. V8 or else ...
Post #724070 6th Sep 2025 2:51pm
Dixy
Thanks
Those were the ones I had settled on. letters not necessarily in the right order
Post #724076 6th Sep 2025 3:38pm
Dixy
A virtual beer to Fisha.
Job done.
The tip about undoing the bar made all the difference.
For those going to do it a few tips.
A 13mm ratcheting ring spanner makes undoing the bar easier and without that access to the outside front nut is almost impossible.
Slacken off the lower nut and bolt as soon as the wheel is off.
2 trolley jacks made it a lot easier.
There is absolutely no need to remove the rear seats. letters not necessarily in the right order
Post #724417 12th Sep 2025 6:40pm
fisha
Great stuff. Was actually a relatively straight forward job in hindsight. V8 or else ...
Post #724462 13th Sep 2025 11:27am
