Home > eBay & Bargain Spots > T91R Remote Heater replacement fob
JonnyCJ
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Sumatra Black
For anyone who needs a fob for their remote heater.
https://www.ebay.co.uk/itm/176693256957
I offered £35 and it was accepted. Awaiting delivery.
Although branded Peugeot they should work just fine if you have a T91R receiver. Check in the right hand side of the load area. There's a panel that pulls out and the receiver should be behind there.
It's getting colder - don't delay !
Post #724402 12th Sep 2025 12:50pm
Rove Ranger
England 2012 Range Rover Vogue SE 4.4 V8 Orkney Grey
Took £30 off me 😁
Who can get it for less!
Post #724604 15th Sep 2025 6:12pm
JonnyCJ
Smashing ! Once they’re gone they’re gone…
Post #724605 15th Sep 2025 6:31pm
NOTSHARP
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Worth a try.
Steve. “He that strikes the venison first shall be the lord o' the feast.” — Shakespeare, King Lear.
2012 Vogue SE. 4.4 TDV8, Sumatra Black
Post #724611 15th Sep 2025 7:59pm
Rove Ranger
Anybody managed to pair their remote?
Post #724800 19th Sep 2025 1:02pm
JonnyCJ
Mine paired first time. Been too warm to use it though.
Think the ambient temp needs to be below 13c or something near that.
Post #724801 19th Sep 2025 1:06pm
Nickcoll89
United Kingdom 2011 Range Rover Vogue TDV8 Rimini Red
What shape and year RR’s are you successfully pairing these with?
Post #724837 20th Sep 2025 10:52am
JonnyCJ
2012,VSE L322
Post #724840 20th Sep 2025 11:27am
Andyyav
United Kingdom 2018 Range Rover Vogue SE SDV8 Carpathian Grey
Doesnt work on my 2016 ask me how i know....... Embarassed 1972 Series 3 full of character
1985 90 pick up went anywhere
1992 90 Exported
2007 L322 that was an experience
2010 D4 more versatile than a Swiss army knife, now gone
2011 L322 4.4 VSE traded in
2018 L405 4.4 VSE Sold a wrong un
2016 L405 4.4 AB
Post #724877 21st Sep 2025 10:48am
JonnyCJ
Great to hear your T91R remote is paired! Here’s how to use it with your 2012 Range Rover, assuming it’s connected to the Webasto Fuel Burning Heater (FBH) system:
🔧 Basic Operation of the T91R Remote
• Turn On the Heater:• Press the ON button briefly.
• The LED will flash to confirm the signal was sent.
• Your FBH should start warming the vehicle.
• Turn Off the Heater:• Press the OFF button briefly.
• The LED will flash again to confirm the signal.
• The heater will shut down.
🔁 Adjusting the Operating Time
To change how long the heater runs:
1. Press ON and OFF simultaneously three times quickly.
2. The LED will flash to indicate the current operating time.
3. Press OFF within 10 seconds to cycle to the next time setting.
4. Repeat until you reach your desired duration.
Typical durations are 10, 20, 30, 40, 50, or 60 minutes depending on your system.
🚗 Vehicle Settings Before Use
Make sure:
• The climate control is set to warm.
• The fan is on low speed to reduce power draw.
• The vehicle battery is in good condition (FBH can drain it if used frequently).
📶 Signal Tips
• Use the remote within range (usually up to 100 meters).
• If the LED flashes rapidly and then turns off, the signal didn’t go through—try again from a different spot.
For a visual walkthrough, you might find this YouTube video on Webasto FBH and T91 pairing helpful A. And if you want the full manual, it’s available here B.
Let me know if you want help checking your heater settings or troubleshooting signal issues!
Post #724899 22nd Sep 2025 6:20am
Nickcoll89
I’ve put two offers in now and no one’s responding, were they fairly quick with everyone else?
Post #724921 22nd Sep 2025 3:04pm
NOTSHARP
I sent the seller an offer message via ebay, and he responded immediately, sending me a message offfering a discount.
It was delivered today, so a very quick response all round.
Post #724923 22nd Sep 2025 3:09pm
Rove Ranger
Yep, made an offer in the evening after work - accepted it early the next day, delivered 2 days after that.
I just can't get the bloody thing to pair.
Post #724932 22nd Sep 2025 4:17pm
NOTSHARP
Would you be good enough to explain the pairing process, please.
'pairing for dummies' version. Very Happy
Post #724933 22nd Sep 2025 4:20pm
Nickcoll89
What model and year RR do you have? There are many types of remote. One with “on” and “off” text and one with the heater symbol with arrows an off like this one.
This post details about which vin numbers potentially use which remotes.
https://www.fullfatrr.com/forum/post644977.html#644977
Post #725021 24th Sep 2025 8:10am
