![]() | Home > Technical (L322) > LR019451, rear brakes and some quick queries |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 1010 ![]() ![]() ![]() |
I went with ( after some discussion with my indie mechanic ) , EBC Greenstuff Pads all round, and they do the job remarkably well IMHO
diabloam Member Since: 22 Oct 2024 Location: Isle of Lewis Posts: 38 ![]() ![]() ![]() |
sorry, just looked, its greenstuff pads I have ordered, got them mixed up in my head, looked at point of ordering and sussed the green were better for normal road. They been ok? |
yes great pads in my view, does the job, even with my 3 ton trailer on the back |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1342 ![]() ![]() ![]() |
+1 for the greenstuff pads.
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 430 ![]() ![]() ![]() |
I had this problem
They ain't cheap , lol, front and rear discs and pads, fitting kit for pads for front 6 pots, handbrake shoes plus fitting kit (will need to suss something here as shoe retaining pin pulled through the backplate and no backplates available, out of stock) fuel filter and a GKN rear propshaft, grand total £1025, ouch, lol
I'll wager we are probably the only two people crazy enough to do this, drilled and slotted rear discs (mine were from Australia and made by PPD Performance Size 365mm ) and EBC Green Stuff pads |
How have they performed? They were no more expensive than OE so hopefull. Do you think its a crazt decision? |
also, which way did you do grooves and why, got conflicting views online about this |
they do the job, no complaints here, the crazy part is that I never see slotted and drilled rear discs on Range Rovers, even SVR's
you have them on the correct way ![]() |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3337 ![]() ![]() ![]() |
The groves and holes could help clean the pads and keep the disk surface rust free as the rears on these don't do much in normal driving and rust can start to creep in from the disk edges leading to even less braking. Remember to tell your insurer as these are classed as a modification. 2012 TDV8 Vogue (L322) |
