Home > Technical (L322) > Egr mapping out 3.6 2010
Apps
United Kingdom 2010 Range Rover SE TDV8 Santorini Black
Anyone had there egrs mapped out on a 3.6? Any advice/is it worth it? [/i][/list]
Post #724682 17th Sep 2025 4:07pm
toby1
I don't think the 3.6 needs mapping, just blanking off.
I am sure if you search on here you will find the answer. 2012 Vogue TDV8 in Aintree green over sand
Post #724694 17th Sep 2025 5:45pm
chris_read
England 2009 Range Rover Vogue TDV8 Stornoway Grey
As Toby suggested above I just blanked mine and had no issues at all. You notice the difference immediately, especially when setting off from junctions onto busy main roads. 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family šŸ˜€
2009 3.6 V8 (MY2010) - my first ever diesel! - now also gone Sad
2004 4.4 V8 Petrol Vogue - now gone
Post #724695 17th Sep 2025 7:00pm
JayGee
Best to map it out as blanking just prevents the EGR gases from circulating but the valve is still operating and it's this that breaks apart and does the damage. 2012 TDV8 Vogue (L322)
Post #724776 19th Sep 2025 7:54am
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
If you blank both sides of the egrs there's no worries about broken egr valve head parts going anywhere. However unless electronically mapped out they can still fail electrically and cause fault codes - even if not causing any other running issues. Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #724781 19th Sep 2025 8:28am
Red Hot one
United Kingdom 2009 Range Rover Vogue TDV8 Stornoway Grey
I blanked mine, all fine, after 3 years there was an error message, did the BAS EGR delete on the IID no further problems.
Will
Post #724816 19th Sep 2025 6:17pm
Apps
Cheers. From what Ive read and been told the 3.6 doesn't have any issues with just blanking the egrs. Did u notice and improvements?
Post #724820 19th Sep 2025 8:10pm
Red Hot one
I did the EGR delete as soon as I got the car home, so no, I don't have any comparison for a before or after. Seeing the state of the EGR pipes after removing them it is quite worrying the amount of cr*p going back into the combustion chambers, I do change the oil twice a year under the motto oil is cheaper than metal, especially turbos, the gearbox oil is changed every 30K, maintenance is everything as far as I'm concerned and preventing the EGR from destroying the engine is part of that philosophy.
Post #724821 19th Sep 2025 8:48pm
Some need a remap after blanking out otherwise the EML light will come on.
I did mine and used the BAS remap and all was well. Got - 2017 SDV8 Autobiography in Loire Blue
Post #724822 19th Sep 2025 9:05pm
Apps
What difference did you notice after having them mapped out?
Post #724826 19th Sep 2025 9:37pm
Honestly? None that I can recall. I did it more to avoid issues caused my failures. Got - 2017 SDV8 Autobiography in Loire Blue
Post #724829 19th Sep 2025 11:48pm
chris_read
I had a very small improvement in MPG but the main difference in my car was the removal of the momentary lag when pulling out of a junction or setting off from traffic lights.
One of my EGR valves threw a fault so I replaced both (that was fun 😬) prior to blanking them. 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family šŸ˜€
Post #724831 20th Sep 2025 7:41am
