![]() | Home > Maintenance & Mods (L322) > Rear toe control arm replacement |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3334 ![]() ![]() ![]() |
It's an easy enough job to do but the steel bolts will more then likely be seized into the aluminium centre of the bush in the toe control arm. I've replaced them on 2 different cars now and have had to cut them off on both cars so ensure that you order nuts and bolts when you order the toe control arms. |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6428 ![]() ![]() |
On both of my L332's I had to use a hacksaw to cut through the nut on the hub end joint in order to be able to remove the toe control arm. Other than that, iirc, straightforward unbolt old and bolt on new. .
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 433 ![]() ![]() ![]() |
have a reciprocating saw handy
TOMC73 Member Since: 03 Mar 2024 Location: Warwickshire Posts: 19 ![]() ![]() ![]() |
thanks for the advice |
