![]() | Home > Technical (L322) > Wire leading to brake pad sensor, repair? |
Happydaze Member Since: 30 Aug 2021 Location: Wirral Posts: 116 ![]() ![]() ![]() |
Just been through this. I'd forget about it. It's only to tell you your pads are getting towards the end of life and before you start gouging the disc. But if you're supposed to fit discs with the pads what's the point? Probably so that 'Sir' can book into the dealership with plenty of notice! More modern variants probably flash up warnings of imminent death and don't allow you to not drive directly to the dealership! |
Full-fat-Lance Member Since: 06 Feb 2022 Location: Essex Posts: 152 ![]() ![]() ![]() |
I had this happen in the past after changing my brakes; either i didn’t put it in place at all or didn’t put it in place properly. For the minimal price and effort of the new one, i just replaced it. |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1552 ![]() ![]() |
It'll not affect the actual braking of the car, so fine to drive without. Replace when you get the chance.
DeeJay Member Since: 16 Oct 2021 Location: Western Cape Posts: 45 ![]() ![]() ![]() |
thank you Fisha 2011 Vogue SE 4.4 TDV8 |
