|  | Home > Camping, Caravanning and Holidays > Strange anomaly |
| GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2774    | Possibly the starter solenoid is on its way out and needs more voltage when hot. L405 D350 SE Carpathian Grey D5 19" rims | ||
|  25th Sep 2025 2:47am |
| kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1364      | It's just had a new starter.
|  25th Sep 2025 3:53am |
| Monty+4 Member Since: 25 Oct 2023 Location: Argyll Posts: 24      | There are two 12v feeds to the caravan, the constant 12v to the caravan battery and the ignition on feed via a relay for the fridge etc. I would try and identify which one is causing the issue, on my 405, the two fuses are in the load space fuse box. | ||
|  25th Sep 2025 9:08am |
| kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1364      | Thanks for the info. I will have a look.
|  25th Sep 2025 9:34am |
| Monty+4 Member Since: 25 Oct 2023 Location: Argyll Posts: 24      | Possibly because on the first start, the trailer wont have been detected until you indicate or brake though, that could be a red herring, I cant think of another reason unless the relay is sticking. Have you checked the connections where the cable comes into the caravan, I have found on mine two connections on the feed to the fridge which have become very hot at some point, burnt connectors could be causing a voltage drop. | ||
|  25th Sep 2025 2:23pm |
| Bardley Member Since: 01 Jan 2025 Location: Hertfordshire Posts: 58      | Checked Brake light Bulbs?
|  25th Sep 2025 2:54pm |
| kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1364      | Both interesting things to look at. Thanks. | ||
|  25th Sep 2025 3:33pm |
| All times are GMT + 1 Hour | < Previous Topic | Next Topic > |
| Posting Rules
