Home > Camping, Caravanning and Holidays > Strange anomaly
kevinp
Strange anomaly
I've been towing different caravans for the last five years with my 4.4tdv8.
Last month I hitched the van and the car started fine and off we went.
After a few hours we pulled into a lay-by for a break.
When we come to set off again the engine wouldn't start. Ignition lights came on but nothing happened when pressing the start button. No clicks or anything.
I started checking fuses and swapping relays around. It was going to be a 4 hour wait for the RAC.
I don't know what made me do it but I disconnected the caravan 13 pin plug from the car and it started instantly as if there was nothing wrong.
I reconnected the van and everything was fine.
It did exactly the same whilst towing last week.
Can anyone give me any pointers at all as to what is wrong?
Post #725054 24th Sep 2025 11:23pm
GraemeS
Australia
Possibly the starter solenoid is on its way out and needs more voltage when hot. L405 D350 SE Carpathian Grey D5 19" rims
Post #725056 25th Sep 2025 2:47am
kevinp
It's just had a new starter.
Don't understand why disconnecting the caravan plug lets it start straight away.
There is a bit of corrosion on the plug wires that I'm going to clean up which might be effecting the cars electrics perhaps?
Thanks.
Post #725057 25th Sep 2025 3:53am
Monty+4
United Kingdom 2019 Range Rover Autobiography TDV6 Loire Blue
There are two 12v feeds to the caravan, the constant 12v to the caravan battery and the ignition on feed via a relay for the fridge etc. I would try and identify which one is causing the issue, on my 405, the two fuses are in the load space fuse box.
Post #725062 25th Sep 2025 9:08am
kevinp
Thanks for the info. I will have a look.
I just don't understand why the first start up at home is okay but subsequent start ups are a problem the last two times we've used the van.
Post #725063 25th Sep 2025 9:34am
Monty+4
Possibly because on the first start, the trailer wont have been detected until you indicate or brake though, that could be a red herring, I cant think of another reason unless the relay is sticking. Have you checked the connections where the cable comes into the caravan, I have found on mine two connections on the feed to the fridge which have become very hot at some point, burnt connectors could be causing a voltage drop.
Post #725083 25th Sep 2025 2:23pm
Bardley
United Kingdom 2014 Range Rover Autobiography SDV8 Corris Grey
Checked Brake light Bulbs?
There's a link, and if they're filament types and not 100% it can affect the startup. L405 2014 SDV8 4.4 Autobiography
Corris Grey
Previously 2011 D4 SDV6 HSE Santorini
Post #725084 25th Sep 2025 2:54pm
kevinp
Both interesting things to look at. Thanks.
Post #725087 25th Sep 2025 3:33pm
