Home > Technical (L322) > Rear differential oil for “e diff” (If I have one)
Jonester
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Santorini Black
I’ve looked through the posts on changing differential oil but I can’t find anything related to my issue.
I’ve read that my 4.4 TDV8 may have a rear “e diff” as it was put on some autobiography and supercharged models. Apparently the e diff needs a different oil to the standard one, my issue is how do I tell which rear differential I have as Land Rovers computer system is still down so I can’t check with them. Google image searches were no help, so my question is, what do I need to look for if I need to do a visual check? Or is there any other way of determining it?
Thanks in advance.
Post #725142 26th Sep 2025 11:19am
Rove Ranger
England 2012 Range Rover Vogue SE 4.4 V8 Orkney Grey
Put it into rock mode and if you have 2 padlocks on the dashboard speedo then you have the locker. Alternatively put your vin into vindecoderz and it'll tell you on there.
Rare as rocking horse Censored if you have it. I looked for 2 years and gave up.
Post #725151 26th Sep 2025 1:28pm
Gremlin500
@Jonester,
Yes you will in all probability have the e-diff.
Easy to tell the difference, the “open” diff has no wires or plugs connected to it, nor the actuator motor on top, like this:
The Wiki above has more information, if you search it. Thumbs Up V6 Vogue - “Less is More” - less to go wrong!
Post #725156 26th Sep 2025 2:00pm
Gremlin500
Sorry, hadn’t realised its L322, not L405 Embarassed V6 Vogue - “Less is More” - less to go wrong!
Post #725159 26th Sep 2025 2:19pm
Jonester
I’m hoping I don’t have it as the oil is more expensive lol Tbanks very much mate, greatly appreciated. 👍
Post #725164 26th Sep 2025 3:34pm
Rove Ranger
If you have it, I'll swap with you 😂
Post #725168 26th Sep 2025 4:53pm
