Home > Technical (L322) > TDV8 4.4 primary turbo actuator - where is it ?
kevinp
Yes mate. Two screws/bolts either end if I remember right. Just make sure you don't lose the rubber 'O' ring at the plenum end.
Post #677660 10th Nov 2023 11:48am
Vogue4.4tdv8
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
Mine does this too
Start recently
My car is egr and dpf deleted with stage one map
I must say lately it doesn't feel as pokey on the small turbo like to use too
Sticky vanes or the bypass valve ?
Post #725247 27th Sep 2025 11:24pm
JayGee
The small turbo is the 2nd turbo that comes in at 2500rpm to top up the airflow. I'd check for air leaks and clean the MAP sensor. MAP sensors need cleaning as often as 1k mile intervals IME. 2012 TDV8 Vogue (L322)
Post #725262 28th Sep 2025 9:57am
Vogue4.4tdv8
Map was cleaned few hundred miles ago
Was sooted up badly
The inlet elbow pipe is loose
Maybe needs the 3 o rings fix ?
Post #725263 28th Sep 2025 10:00am
JayGee
Defo try the O ring fix esp if there is oily gunk around the joint. If you had an EGR delate there should be no soot buildup on the intake. Did you also have an egr blanking plate fitted? 2012 TDV8 Vogue (L322)
Post #725265 28th Sep 2025 10:44am
Vogue4.4tdv8
I know it's dpf deleted and stage 1 map
How do i check if egr is blanked ?
Will give the inlet manifold o rings a go
Can bad turbo bypass valve cause it ?
Post #725266 28th Sep 2025 11:02am
JayGee
If you have soot in the intake the EGR valve is still working Wink
You can't just blank the EGR without removing it in the software so contact the tuner who did the remap to advise. 2012 TDV8 Vogue (L322)
Post #725267 28th Sep 2025 11:27am
Vogue4.4tdv8
So the occasional flutter on low revs and kangaroo could be a small boost leak ?
No codes or eml for the turbo bypass valve
Post #725268 28th Sep 2025 11:32am
JayGee
Could be many things but fixing the TB leak is cheap and easy so see what happens after doing that. 2012 TDV8 Vogue (L322)
Post #725272 28th Sep 2025 11:56am
Vogue4.4tdv8
Thanks
On my list of to do
Very annoying when it does that who kangaroo
I'm not seeing any leaks around the throttle body inlet elbow since i changed the o ring on the air temp sensor
Post #725273 28th Sep 2025 12:32pm
