|  | Home > Technical (L322) > TDV8 4.4 primary turbo actuator - where is it ? |
| Vogue4.4tdv8 Member Since: 01 Sep 2025 Location: England Posts: 15      | Mine does this too
|  27th Sep 2025 11:24pm |
| JayGee Member Since: 27 Jul 2021 Location: London Posts: 3404      | The small turbo is the 2nd turbo that comes in at 2500rpm to top up the airflow. I'd check for air leaks and clean the MAP sensor. MAP sensors need cleaning as often as 1k mile intervals IME. 2012 TDV8 Vogue (L322) | ||
|  28th Sep 2025 9:57am |
| Vogue4.4tdv8 Member Since: 01 Sep 2025 Location: England Posts: 15      | Map was cleaned few hundred miles ago
|  28th Sep 2025 10:00am |
| JayGee Member Since: 27 Jul 2021 Location: London Posts: 3404      | Defo try the O ring fix esp if there is oily gunk around the joint. If you had an EGR delate there should be no soot buildup on the intake. Did you also have an egr blanking plate fitted? 2012 TDV8 Vogue (L322) | ||
|  28th Sep 2025 10:44am |
| Vogue4.4tdv8 Member Since: 01 Sep 2025 Location: England Posts: 15      | I know it's dpf deleted and stage 1 map
|  28th Sep 2025 11:02am |
| JayGee Member Since: 27 Jul 2021 Location: London Posts: 3404      | If you have soot in the intake the EGR valve is still working  | ||
|  28th Sep 2025 11:27am |
| Vogue4.4tdv8 Member Since: 01 Sep 2025 Location: England Posts: 15      | So the occasional flutter on low revs and kangaroo could be a small boost leak ?
|  28th Sep 2025 11:32am |
| JayGee Member Since: 27 Jul 2021 Location: London Posts: 3404      | Could be many things but fixing the TB leak is cheap and easy so see what happens after doing that. 2012 TDV8 Vogue (L322) | ||
|  28th Sep 2025 11:56am |
| Vogue4.4tdv8 Member Since: 01 Sep 2025 Location: England Posts: 15      | Thanks
|  28th Sep 2025 12:32pm |
| Posting Rules
