![]() | Home > Technical (L322) > FBH Changeover Valve |
jaguar3 Member Since: 25 Sep 2022 Location: Estonia Posts: 194 ![]() ![]() ![]() |
Here good video about how LR pre-heaters with different makes/systems works in stock.
AdrianL322 Member Since: 06 Sep 2022 Location: Ås Posts: 15 ![]() ![]() ![]() |
Reading the workshop manual it seems that the changeover valve is "open" when engine is runing. If that's correct I can't see how the valve position effect warm-up time when driving because the FBH will not be isolating the heater matrix from the rest of the system.
Westridge177 Member Since: 12 Oct 2021 Location: Birmingham Posts: 27 ![]() ![]() |
Just by way of an update it seems that going for the eBay special wasn’t the right choice, after weeks of chasing a very slight leak, and skinning my knuckles changing the hose clamps for jubilee clips and wasting another 5L of coolant I have realised that the valve itself leaks intermittently. Just waiting on the motor factors to confirm return or refund.
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2282 ![]() ![]() ![]() |
where did it leak from? I ordered a cheap one then saw this! I can only see it could Leak where the solenoid joins the body - thinking I could do instant gasket for belt and braces here? Current stable:
It’s a while back now, but I think you are right it was from the join. |
