|  | Home > My Range Rover > My latest project L322 5.0 SC Autobiography Black |
| JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 965    | Thanks and good to get another opinion against a solid coupler 👍
|  4th Oct 2025 4:26pm |
| Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1057    | My solid coupler came from power house in their rebuild kit for the snout.
|  4th Oct 2025 4:53pm |
| JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 965    | I’ve made good progress over the past few days on replacing the timing chain tensioners & guides.
|  17th Oct 2025 3:58pm |
| JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 965    | A big thank you to forum member RS2000CUSTOM who very kindly sent me a blanking plate for the symposer delete modification   | ||||||||
|  17th Oct 2025 4:37pm |
|  17th Oct 2025 5:41pm |
| JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 965    | A bit more progress over the past couple of days, removed the old & fitted the new tensioner & guide to the right hand bank, ensured the timing was aligned across both banks & the crankshaft, carefully cleaned all the mating surfaces then started re-assembly.
|  28th Oct 2025 6:25pm |
| Richie N Member Since: 29 Dec 2023 Location: Kent Posts: 434      | Top work 👍 no need to replace the chains too then? | ||
|  28th Oct 2025 9:06pm |
| JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 965    | The main reason for starting this job was to replace the SC coupler, which had some play and fix a small coolant leak from somewhere around the oil cooler, but decided whilst I was at it to upgrade the tensioners and guides with the latest versions.
|  28th Oct 2025 9:24pm |
| Posting Rules
