![]() | Home > Maintenance & Mods (L322) > 5.0 supercharged oil service - oil low |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8826
The engines are designed to supply oil at some silly angles when off roading, they always carry much more oil than they need in normal driving, it should be fine, just replace with the correct amount but don't overfill it.
| JayGee Member Since: 27 Jul 2021 Location: London Posts: 3404
If the oil was too low it would cause a low oil pressure warning on braking, accelerating or cornering. Unlikley this would be turned off in the PID even if for some inexplicable reason the oil level warning was. 2012 TDV8 Vogue (L322) |
| RRD Member Since: 19 Mar 2014 Location: Antwerp Posts: 43
Ended up filling it with 7.5 liters of 5w20 to get it to the correct level. I called my local Land Rover mechanic and he confirmed that there's no hard fault on the dash with these cars for low oil level.
| dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3350
On the 5.0 engine there is no oil pressure switch so you won't get a low oil pressure warning |
| Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2310
How is the car running? I just did this and got about 3.5l throught the vacuum tube |
Not only is there no low oil level warning, there's no low oil pressure warning either.
But that’s ludicrous- the sensor is very accurate when cold I can read with my dish tools no problem so surely they could just make it to when to reads leads than say 6l before starting it flashed up top up oil?
Car is running fine but I'm checking oil level every 5 - 800 km now. Just to be sure. '17 Range Rover 5.0 Supercharged AB (Sold) '16 Range Rover SDv8 AB (Sold) '15 Range Rover SDv8 Vogue (Sold) '13 Range Rover SDv8 Vogue (Sold) '12 Range Rover TDv8 (Sold) '10 Range Rover 5.0 Supercharged '03 BMW E39 M5 '01 BMW E46 M3 |
Does it burn much?
I do around 8000 miles a year in mine with an oil change every 6 months and it’s never used a drop of oil in between services. |
| All times are GMT |
