Home > General (L460 2022) > P550e vs P460e specs
ffrrman
Nice one! I got so much discount that my AB was cheaper than a SE! Those days are long gone now max discount I can see on a Hybrid AB is around £8k now.
Post #705083 21st Nov 2024 6:26pm
NDT
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
ffrrman wrote:
Its not a remap at all its a change in "settings" as per factory programming via the JLR systems. ive had mine 3 months now and no issues whatsoever. Each to their own but Im very happy with the £400 I spent having mine done - I didnt use these guys by the way. The guy who did mine works for JLR on the production line and does this "on the side". Very Happy
How does it affect the warranty?
Post #705219 23rd Nov 2024 12:16pm
ffrrman
Its untraceable as not a menu that any engineer would need to go in to from what I been told by the techy who did mine! Its a factory setting.
Post #705221 23rd Nov 2024 12:32pm
Belgravia123
Hi. I have a P460e and am interested in the upgrade / software flash to P550e performance. Would you kindly be able to advise where this can be done? Thanks so much.
Post #722763 12th Aug 2025 9:21pm
Anh012345
550e vs 460e
I’m wondering if it’s worth holding out for P550e - there is a 460e in the right spec available but not a P550e. Is the power upgrade really worth it? I’ve got a Porsche 911 GTS so I’m not buying this as a sports car but equally keen to know if the power upgrade makes a noticeable difference? Thanks
Post #725654 5th Oct 2025 3:23pm
Anh012345
Ffrrman
Hi Ffrrman
Any chance you could pm me? I haven’t posted enough to be able to contact you but would be keen to find out more about power upgrade.
Best
Post #725655 5th Oct 2025 3:25pm
JackRegan
As mentioned in this thread, I went for the 550e. Mainly because all the deals for the 460e had been snapped up.
Drive a 460e and see what the £ difference is for a 550e. I doubt you'll find the 460e lacking in power.
Go for the one with the right spec at the right price.
One thing to mention, four-wheel steer. I'm not sure if this comes as standard on the 460e. I find this a great feature.
Good luck Thumbs Up 2024 P550e Autobiography
2016MY TDV6 Autobiography
2011MY 5.0 SC Autobiography Black
2005 TD6 Vogue
Post #725680 5th Oct 2025 10:33pm
Anh012345
P460e
Yep the 460e comes with all wheel steer. I think the main physical difference is the size of front (and back?) calipers?
Thanks for the advice.
Post #725693 6th Oct 2025 10:25am
Clipper
P550e comes with the dynamic drive, or whatever it's called, that apparently helps control in corners.
Post #726981 27th Oct 2025 1:55pm
