![]() | Home > General (L460 2022) > P550e vs P460e specs |
| NDT Member Since: 03 Apr 2018 Location: Bedfordshire Posts: 106
How does it affect the warranty? |
| ffrrman Member Since: 04 Oct 2021 Location: South Bucks Posts: 38
Its untraceable as not a menu that any engineer would need to go in to from what I been told by the techy who did mine! Its a factory setting. |
| Belgravia123 Member Since: 12 Aug 2025 Location: Sadberge Posts: 2
Hi. I have a P460e and am interested in the upgrade / software flash to P550e performance. Would you kindly be able to advise where this can be done? Thanks so much. |
| Anh012345 Member Since: 05 Oct 2025 Location: Berkhamsted Posts: 4
I’m wondering if it’s worth holding out for P550e - there is a 460e in the right spec available but not a P550e. Is the power upgrade really worth it? I’ve got a Porsche 911 GTS so I’m not buying this as a sports car but equally keen to know if the power upgrade makes a noticeable difference? Thanks |
Hi Ffrrman
| JackRegan Member Since: 20 Oct 2012 Location: Wirral Posts: 267
As mentioned in this thread, I went for the 550e. Mainly because all the deals for the 460e had been snapped up.
Yep the 460e comes with all wheel steer. I think the main physical difference is the size of front (and back?) calipers?
| Clipper Member Since: 11 Sep 2022 Location: Surrey Posts: 68
P550e comes with the dynamic drive, or whatever it's called, that apparently helps control in corners. |
| All times are GMT |
