Home > Technical (L322) > TDV8 turbo noise
Chlorothalonil
United Kingdom 2008 Range Rover Vogue SE TDV8 Buckingham Blue
Turbo noise, and now broken at the dealer
Took the car to a main dealer to diagnose it. No call with a progress update so I rang them...
Somehow, they have managed to get a coolant hose to split and it has dumped its coolant. No hose in stock. No previous cooling issues. Can't wait to get it back, I just hope the engine is ok after this little bit of bad news.
Monday can't come soon enough.
Post #582603 6th Feb 2021 6:06pm
Chlorothalonil
Finally got the car back, complete with big bill and a new nearside turbo and a coolant pipe.
Post #583498 13th Feb 2021 1:15am
uzp315
Fingers crossed... Is the noise fixed?
Sorry to ask, how much was the turbo replacement?
Post #586094 3rd Mar 2021 7:49pm
Chlorothalonil
All sorted.
Including the coolant pipe replacement, a whopping £3700!
Post #586114 3rd Mar 2021 9:45pm
uzp315
Thanks for sharing that, and it's good to hear it is sorted, and that you now have peace of mind. I had a lot of bills to deal with in the first months after the purchase, and no regrets four years later and nearly 40k miles on top. I trusted the car on a tour around Europe and a 110 mile daily commute. No regrets Smile
Post #586117 3rd Mar 2021 9:53pm
Chlorothalonil
I know some specialists mentioned on here would do both for less, but in this area I had a bad experience with one of them and was left a bit disillusioned.
Post #586140 3rd Mar 2021 11:28pm
uzp315
Not ideal at all, but at least you have it sorted and plenty of recourse with main dealer if needed.
I'm hoping i don't need the work, but at £3700 main dealer prices I think I would foot the bill and get it done if ever needed.
Cheers
Mark
Post #586174 4th Mar 2021 10:28am
clickhearth
Norway
First post, long time reader.
2011 Range Rover 4.4 TDV8
Hi folks,
I’m puzzled with similar situation. Here’s what I know: noise coming from left side (LHD car), it seems to be whistling and bit higher pitch noise, only under heavier acceleration (40%+), no matters which gear, not in specific RPM range (with proper pedal position and load, noise is present from ~1500 rpm to the end), AC on/off does not matter, no significant error codes.
Recently did brake disks and pads + standard oil and filters service — but it was also happening before.
Based on this thread I suspected turbocharger, but consulting the mechanic, he mentioned potential exhaust manifold gasket having issues or manifold warping itself (seen it on 3.6 before). I suspect it’s a high pressure related thing just not sure where.
I’d be keen to install magnetic microphones and pinpoint the source. This might help narrow things down. But not in possession of those now.
I’d like to pinpoint and reduce unknowns as much as possible before potentially pulling out the engine. Would be happiest if it was a hose somewhere.
Turbocharger seems to hold pressure decently.
Edit:
There was a loose hose, bottom left in engine bay when looking from driver’s seat. Can’t reproduce the noise anymore. Hopefully this was the culprit. If true, big save.
Post #725695 6th Oct 2025 11:46am
