Home > Technical (L405) > Deployable tow-bar troubleshooting help - gearbox failure?
Page 2 of 3 <123>
That's right, I've not had to disassemble anything yet - but if you're getting no movement at all it may be forced on you. Mike - MPx
Post #693441 27th May 2024 5:24pm
Silicon or PTFE - which should I use ? I usually get so confused that I put it off & then don't do anything, which may be worse than using the 'wrong' one.
I've not done anything to mine & fear that one day it will refuse to play.
Post #693443 27th May 2024 5:35pm
I don't think there's a wrong one between silicon and PTFE for this application - although the PTFE should last longer. The problem with std WD40 is that despite it spraying on well and quickly working in to the areas needing lubrication, its not actually very good as a long term lubricant - ends up just attracting dust/dirt to hang around. The silicon and PTFE versions spray on the same, but leave a coating on the surfaces which acts as a longer term lube - the low friction nature of both materials means they both work well. But just like anything else, they'll get blasted/wiped/rubbed off over time so need reapplying periodically. Mike - MPx
Post #693447 27th May 2024 6:13pm
Thanks - I'll order a can of PTFE Thumbs Up
Post #693450 27th May 2024 6:26pm
Boatmechanic
Sweden
Rinsed with lots of water and sprayed with rust-dissolving spray.
No signs of dirt or rust on the shaft above the rubber grommet, though, and factory grease left.
Didn't help.
Just ordered a motor and gearbox from PowerfulUK.
When I drop the entire assembly to inspect, I could just as well have one around...
Post #693451 27th May 2024 6:41pm
Boatmechanic
Sweden
Finally received the motor and gearbox on Wednesday.
Now traveling for a couple of weeks. Will report back when there is progress.
Post #694542 16th Jun 2024 1:37pm
Boatmechanic
Sweden
Duplicate
Post #694543 16th Jun 2024 1:37pm
supershuttle
I thought mine was goosed (technical term) as it failed to deploy (or retract for that matter) a couple of times. I just keep trying, holding the button in (not the on/off button) as apparently it delivers a volt or two more to the towbar motor and so far it has always worked for me.
Probably jinxed it now Rolling with laughter Geoff
Post #694556 16th Jun 2024 4:32pm
chris_read
England 2009 Range Rover Vogue TDV8 Stornoway Grey
I had a similar issue with the deployable towbar on my F Pace. It repeatedly failed to go back into the stow position and I was sure it was going to be an expensive fix.
And then I realised that I had forgotten to remove the 13pin to 7 pin adapter…….
Oh how I laughed Censored
(This is probably why I can’t be trusted to drive a FullFat at the moment). 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family 😀
2009 3.6 V8 (MY2010) - my first ever diesel! - now also gone Sad
2004 4.4 V8 Petrol Vogue - now gone
Post #694569 16th Jun 2024 7:23pm
Boatmechanic
Sweden
Fixed it
I finally had time to fix it today.
It was not necessary to remove the tow bar. I only needed to remove the plastic bumper cover along with some other trim pieces. Then there is a plastic lid on top of the tow bar beam which covers the mechanism. The lid was attached with some soft sealant and easy to partially lift up.
Everything looked nice and clean in there.
When I tried to deploy, the motor only turned a little in one direction and then reversed again. No movement of the tow-bar. The motor and gear box sounded very good, though.
Next thing was to disassemble the mechanism at the ball joint. That loosened things up, and it was possible to deploy. Something was stuck, and I think it was the ball joint.
I ran the tow bar in and out a few times while adding some grease to the screw and the ball joint.
Then I put some 3M Duct Tape around the lid and reassembled.
Mission completed.
I didn't need the motor and gear case from Powerful UK.
Post #695669 6th Jul 2024 8:06pm
Good result Thumbs Up
Sounds pretty much like many of my repairs - I end up with new bits that I didn't really need if only I'd dug a little further the first time Confused I fitted a new radio to my boat this week, only to discover that the new one didn't work either. I should really have checked the power supply.....
Post #695679 7th Jul 2024 8:03am
Boatmechanic
Sweden
My thinking was that I’d rather have a spare motor and gear case collecting dust than have to assemble and disassemble twice.
By the way, I learned in the comments to the PowerfulUK YouTube video that you can unscrew the gear box from the motor, so I would at a minimum have had a spare motor.
Post #695683 7th Jul 2024 8:53am
Boatmechanic
Sweden
Update
When trying to deploy the tow-bar one week later, it was stuck again. This time, a strong pull by hand was enough to help the motor and get the tow-bar to deploy.
However, after actually using the car to tow, it now works fine every time.
Post #697572 7th Aug 2024 8:01pm
Boatmechanic
Sweden
6-month update and an important insight
After not using the tow bar between mid December and end of February, it was stuck again. I went through the procedure of bumper removal, greasing what is accessible from above, followed by re-assembly. Then I used it intensively for a weekend, retracted it and drove 160 km round trip in winter conditions the following weekend.
Tow bar was stuck again when we came home.
Not looking forward to another afternoon of disassembly and re-assembly, I tried the steps in the service manual once more:
0. Put the car on a battery charger (service manual says 14V - I was probably at 13.2)
"1 Start engine
2 Stop engine
3 Press the 'Activate' button (the left side switch on the deployable
towbar switchpack) once until the green LED illuminates on the
'Deploy/Stow' button
4 Press 'deploy/stow' button (the right side switch on the deployable
towbar switchpack) and hold down for a maximum of 2 seconds
Does the towbar move?
Yes
GO to A5.
No
Repeat steps 1-4 (above) a further four times (5 attempts in total). Does
the towbar move after a further four attempts?"
At attempt 4 or 5, the tow bar released.
I don't know why 5 is the magic number, but it worked.
Post #714627 22nd Mar 2025 5:52pm
Boatmechanic
Sweden
Here we go again
The magic trick described in the previous post no longer works.
So I disassembled, checked that everything moved smoothly, greased, and re-assembled. Everything was fine. Up-down-up-down-up-down-up-down-up-down-up-down.
Then the car was sitting for one week.
Tried to lower the tow bar, and it was back to swoosh-swoosh-BEEEP.
Since nothing mechanical had changed, I replaced the control module.
Still doesn't work.
Will now try to remove all grease and lubricate with silicone spray instead. Maybe it is the initial work to overcome the grease that makes the control module think that the motor works too hard.
Any further suggestions welcome.
Post #725746 7th Oct 2025 10:11am
Page 2 of 3 <123>
