Home > Technical (L322) > New shoes, adjusted to 6 clicks but HB not great
diabloam
United Kingdom 2012 Range Rover Westminster TDV8 Baltic Blue
Hi all
Recently did rear shoes, discs and pads. I believe I clicked the adjusters till wheel too tight to turn then undid the adjuster 6 clicks or so. Now when I pull the handbrake button, it all sounds fine but it is not quite holding car on hill, partially so it isn't too far away.
So do I wind the adjustor in a click or two or am I best to do the calibration sequence where you drive about and pull HB on umpteen times in a specific service mode on dash? does that make HB adjust or what is actual point of it? is it just to bed shoes in or does it actually adjust anything, any help as to my best way to progress welcome, many thanks
Post #725704 6th Oct 2025 1:23pm
Shaun_
I've had success just adjusting mine the old fashioned way, but my understanding was that when the time comes to replace the shoes it's important to follow the correct procedure that you refer to.
Regards
Shaun 2012 TDV8 Westminster in the New Forest
Also: Land Rover Series 3 SWB, Mercedes 280SL, Classic Mini race replica, VW Golf SV
Previously: Audi A8, RR TDV8 Vogue, Audi Allroad, VW Golf GTI Edition 30, Audi A4 Avant, A8, A4 Sport, A6, VW Golf Mk5, Bora, Golf GTI Mk3, Jetta Mk3, Passat, Jetta Mk1, Golf Mk1
Post #725714 6th Oct 2025 5:03pm
Bardley
United Kingdom 2014 Range Rover Autobiography SDV8 Corris Grey
Have a read here: Brilliant work :
It's a linked part of the forum D3/D4, so hoping it's accepted practice.
https://www.disco3club.co.uk/gallery/album..._V1_6a.pdf
P27
Same setup on D3/D4/RRS..
Note the torque wrench for setting of the star wheel, the additional Allen bolt adjuster, and bedding in procedure.
If I've posted the link out of turn, accept my apologies plse.
Hope it helps. L405 2014 SDV8 4.4 Autobiography
Corris Grey
Previously 2011 D4 SDV6 HSE Santorini
Post #725721 6th Oct 2025 8:14pm
dhallworth
Have you followed the bedding in procedure properly?
Mine was crap before I carried out the bedding in procedure but is much better afterwards.
Post #725727 6th Oct 2025 9:59pm
diabloam
Does the procedure actually tighten up the hand brake, I was under impression its just for bedding shoes in but I would still need to manually adjust them, or am I wrong on this. Has anybody had bad handbrake and done procedure on road and then HB works? I have not done either yet, looking for guidance on which way is best
Post #725745 7th Oct 2025 10:07am
Red Hot one
United Kingdom 2009 Range Rover Vogue TDV8 Stornoway Grey
I did the procedure after removing the brake disks and refitting, the whole procedure is a bit of a faf and you need a fair stretch of quiet road to do it but it does adjust the handbrake.
Will
Post #725748 7th Oct 2025 10:25am
D3Jon
As you say, it's a bedding in procedure, which'll 'marry' the shoes to the handbrake drum - but it'll also properly centralise the shoes. Try re-adjusting them again with the knurled adjuster now that you've applied the handbrake a few times, you may well find it works better after that 2nd adjustment.
If not then something may be incorrectly assembled? Handbrakes on these are usually very effective.
Jon 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #725751 7th Oct 2025 11:18am
diabloam
fairly confident its assembled correctly so will look to adjust a little on the wee knurled wheels and see what like. What has everybody generally adjusted it to, tighten till locked to moving by hand then unwind 6 clicks, what is general consensus?
Post #725825 8th Oct 2025 10:30am
