![]() | Home > Technical (L405) > Oil Analysis Results - Soot in Oil |
Shaun_ Member Since: 02 Feb 2017 Location: New Forest Posts: 92 ![]() ![]() ![]() |
When Millers tested the oil from my 2012 4.4TDV8 they measured oil dilution at 0.5% and soot level at 0.9% which as in your case they suggested was "...approaching a 'caution' level."
linus Member Since: 04 Jun 2025 Location: Herts Posts: 25 ![]() ![]() ![]() |
Interestingly, you got a very similar reading. How many miles had that oil done?
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1878 ![]() ![]() ![]() |
I do similar miles in my TDV6 between oil changes, but MyOilDoctor give the values as “UFM” not % soot. Last 2 samples were 22 then 14, where I understand a level 60 is the warning trigger.
About 3,500 miles, so like yours quite low.
It looks like your UFM readings are good. I don’t know if the values differ depending on who does the analysis though.
It looks like you need to know what the engine's soot % limit is to be able to convert UFM to a percentage? |
hmallett Member Since: 21 Jan 2024 Location: Mid-Wales Posts: 155 ![]() ![]() ![]() |
I thought there was a thread for this already, but maybe I'm getting mixed up with some other car forum. I have had 3 oil analyses done by Millers - 1 for the oil in my car when I bought it, and 2 for oil changes I have done myself, at around 5000 miles. The results for the 5000 mile changes are not that dissimilar to what is in the original post in this thread. Fuel dilution at 1.0%, soot at 0.6% and 0.7%. Slightly more wear metals on my older engine, but no molybdenum in my sample. |
I did wonder about the molybdenum as it is an additive in oils but could also be caused by some issues. It seems low enough so I will keep an eye on it when i next get an oil analysis done. |
