![]() | Home > Technical (L322) > 2006 TD6 Start Issue |
| Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3277
Check your earth straps. John
| sparrowdclxvi Member Since: 31 Mar 2025 Location: Near Coventry Posts: 14
I forgot to say, I tried putting a jumper cable from the battery to the jumper post that it starts from with the jumper pack, and also from the battery to the cylinder head.
IIRC behind the front offside wheel. John
| steve k Member Since: 05 Apr 2024 Location: Berkshire Posts: 66
[quote="sparrowdclxvi"]Hi all
| cass Member Since: 12 Oct 2011 Location: northumberland Posts: 797
I would fit a new Earth strap between the body and engine, it's a very easy way to prove the earth strap rather than finding, cleaning and refitting the originols. |
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3989
Faulty ignition switch? |
It is. It's also perfectly fine. [img]https://photos.app.goo.gl/6G3hQfRTtVfpsjCE9[/img] [img]https://photos.app.goo.gl/wtcxe4H1eP4PVew87[/img] |
[quote="steve k"]
The solenoid is definitely engaging, but the starter motor won't turn. This is backed up by the battery voltage dropping. If the problem was the solenoid, then the jump pack wouldn't make a difference. |
The original is easy to access. Just pull the inner arch liner off, it's only about 5 nuts/screws. If you jack it up on the sub frame, then there is no need to remove the wheel. |
While I'm not ruling that out entirely, why would it start with the jump pack then? |
I'm at a complete loss now.
I'm not sure how to post pictures correctly. If someone can explain what I'm doing wrong, I'll edit the post. |
| TRUCKDOCTOR Member Since: 13 Oct 2025 Location: Hampshire Posts: 9
When you have the not starting issue , if you can , measure the voltage not the resistance along the battery cables and connections, poor cables or connections will be highlighted with a voltage nearing 12 volt depending what the resistance is in the faulty area.
Thanks for all the suggestions, I seem to have fixed it.
| All times are GMT |
