Home > Technical (L322) > 2006 TD6 Start Issue
sparrowdclxvi
Hi all
I've got a very strange start problem on my 2006 TD6.
It started a few weeks ago. First cold day of the year and it sounded like a flat battery. Fired straight up with a jumper pack, so I replaced the battery.
With the new battery it fired up the first two times just fine.
However, that evening it wouldn't start again.
I assumed it was the starter motor so replaced that.
It was then fine for a few days, but now it's doing the same thing.
The ignition turns on fine, and everything works.
Turn the key to crank, and it's like the battery is flat. The starter motor just clicks a few times, then the dash turns off, and then the car resets.
Battery voltage drops as expected, so the starter is engaging and attempting to turn the engine.
However, if I put a jump pack on the posts it will start first time, every time.
If I remove the jump pack, turn it off and straight back on, it will not start. It's like the battery is flat, but it's not.
With the engine running the alternator is charging at about 14V.
Measured straight after turning it off, the battery voltage is 12.7V, and slowly dropping as expected.
I've measured the resistance from the battery to the two posts, and also measured resistance from the battery to the cylinder head. All the measurements are less than one ohm.
I'm stumped.
It had a new alternator last year due to charging issues, but that turned out to be a faulty ignition switch, so the ignition switch is also fairly new.
If anyone has any suggestions, please let me know.
Post #725818 8th Oct 2025 9:39am
Weegie
Check your earth straps. John
GAP iiD BT-Sold
Post #725821 8th Oct 2025 10:11am
sparrowdclxvi
I forgot to say, I tried putting a jumper cable from the battery to the jumper post that it starts from with the jumper pack, and also from the battery to the cylinder head.
There is also no resistance from the battery to the engine blcok.
I'd ruled out the earth straps because of that, but I'll check them.
Any idea where they are?
Post #725823 8th Oct 2025 10:16am
Weegie
IIRC behind the front offside wheel. John
GAP iiD BT-Sold
Post #725824 8th Oct 2025 10:19am
steve k
United Kingdom 2003 Range Rover HSE Td6 Giverny Green
Re: 2006 TD6 Start Issue
[quote="sparrowdclxvi"]Hi all
"The ignition turns on fine, and everything works.
However, if I put a jump pack on the posts it will start first time, every time"
I'm taking a guess here but a clicking starter motor just means the solenoid is at least trying to pre engage the gear so that current then flows to the motor unit. If there is stiction then the battery on its own struggles to fully move the gear far enough to then make the connection from the battery to the motor. The jumper pack adds extra capacity to keep the volts (current) sufficient to overcome the stiction/drag and achieve full movement of the solenoid?
If it were my car I would look at the solenoid connections on the starter motor off and then even remove the motor to assess the solenoid contacts, movement and general connections Current: 2003 TD6 HSE
2004 Vogue SE 4.4
Previous: 1993 Classic 3.9
Post #725896 9th Oct 2025 10:56am
cass
I would fit a new Earth strap between the body and engine, it's a very easy way to prove the earth strap rather than finding, cleaning and refitting the originols.
Post #725907 9th Oct 2025 1:46pm
Faulty ignition switch?
Post #725908 9th Oct 2025 1:49pm
sparrowdclxvi
It is.
It's also perfectly fine.
[img]https://photos.app.goo.gl/6G3hQfRTtVfpsjCE9[/img]
[img]https://photos.app.goo.gl/wtcxe4H1eP4PVew87[/img]
Post #726147 14th Oct 2025 4:02pm
sparrowdclxvi
[quote="steve k"]
sparrowdclxvi wrote:
Hi all
The solenoid is definitely engaging, but the starter motor won't turn. This is backed up by the battery voltage dropping.
If the problem was the solenoid, then the jump pack wouldn't make a difference.
Post #726148 14th Oct 2025 4:03pm
sparrowdclxvi
The original is easy to access. Just pull the inner arch liner off, it's only about 5 nuts/screws.
If you jack it up on the sub frame, then there is no need to remove the wheel.
Post #726149 14th Oct 2025 4:04pm
sparrowdclxvi
While I'm not ruling that out entirely, why would it start with the jump pack then?
Post #726150 14th Oct 2025 4:05pm
sparrowdclxvi
I'm at a complete loss now.
The earth strap is fine, and this is backed up by no voltage warnings when running.
Without the second battery, the start motor just clicks.
With a second battery, it will try to turn over one or two compression cycles, then just die.
With the jumper pack, it will start like nothing is wrong.
It won't start with a second battery, but will start with the jumper pack.
This suggests it needs over 2000 CCA to turn over properly.
If that was definitely the case, then surely there would be sparks somewhere. That's a huge amount of current.
I'm currently leaning to a second faulty starter, but that doesn't really add up.
Post #726151 14th Oct 2025 4:09pm
sparrowdclxvi
It is.
I'm not sure how to post pictures correctly. If someone can explain what I'm doing wrong, I'll edit the post.
Post #726152 14th Oct 2025 4:10pm
TRUCKDOCTOR
United Kingdom 2005 Range Rover Vogue Td6 Epsom Green
When you have the not starting issue , if you can , measure the voltage not the resistance along the battery cables and connections, poor cables or connections will be highlighted with a voltage nearing 12 volt depending what the resistance is in the faulty area.
You may also have a poor cell in the battery even though its new.Just measure the voltage across the battery terminals when cranking.
Good luck.
Post #726158 14th Oct 2025 6:47pm
