Home > Maintenance & Mods (L405) > What to do with the Sunroof drains
What should I do with the sunroof drains?
Should I Replace and repair
100%
 100%  [10]
Should I Fill with Marine silicone and leave well alone
0%
 0%  [0]
Do I temporarily fill with marine silicone until I can repair
0%
 0%  [0]
Total Votes: 10
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
Now here's the dilemma,
I finally plucked up the courage to check the sunroof drains today.....
DrF
Post #725909 9th Oct 2025 2:01pm
sullivj
United Kingdom 2014 Range Rover Autobiography SDV8 Santorini Black
Don't just fill it with silicon. The water has to go somewhere... Yes, it flood out of the front or back of the tray when you use the car, but if there's enough of it, it could also spill into your B pillar and we all know how that ends!
You're only seeing half of the story from above. Drop the headliner and it will help you decide what to do next.
I've fixed mine today. Take a look here. It's not as bad as you think once you get into it - especially if you know how to take the bloody vent / light out!
https://www.fullfatrr.com/forum/post725917.html#725917
Post #725918 9th Oct 2025 4:01pm
DrF
Thanks for the words of encouragement sullivj,
I have just made up an order of parts, so looks like it might be a job that needs doing before the weather turns. The thing that scares me most is removal of the B pillar trim and headliner as they are leather, and I have never removed the B pillar covers. Like you say once you're there it's probably not that scary, and if I am going to do one i might as well do both.
Any advice on trim removal and replacement would be gratefully received. Can't stand a rattle from broken clips!!
Plenty of daylight, time and cups of tea is all i need, and the obvious words of encouragement from you guys. Thumbs Up Thumbs Up
Post #725922 9th Oct 2025 5:09pm
sullivj
Trim removal was easy. Just pry open the ‘airbag’ signs to reveal the torx screws or bolts. Once they’re removed, a good ‘yank’ removes the trim and none of my clips broke.
There are lots of different types of lights / vents in the headliner (I’ve watched ALL the videos - LOL!). If yours is like mine, you now know how to remove it.
You may be able to get away with ‘just’ sleeving the pipe like I did and kurusting the surface rust on your tray. Where in the country are you?
Post #725925 9th Oct 2025 5:16pm
DrF
Evening sullivj
Thanks for the help, much appreciated.
Post #725928 9th Oct 2025 5:50pm
sullivj
I can’t be certain, but it probably works on the same principle because you can’t release it around the edge.
Post #725936 9th Oct 2025 6:47pm
I had a very corroded one that must have been completely blocked. As soon as I touched it, it gave way and I was left with a hole Shocked
BluTac worked fine for a couple of weeks, including some heavy rain, until I was able to fix using some inserts.
Post #725946 9th Oct 2025 9:00pm
sullivj
How did you fix it Alistair?
Post #725950 9th Oct 2025 9:13pm
Hep2o inserts -
https://www.fullfatrr.com/forum/topic74149.html
On the good side it went straight in - after rust eater applied & epoxy used.
On the corroded side I needed an extra bit of pipe to make the connection.
Post #725952 9th Oct 2025 9:24pm
Harry858
United States
on MY'21 I checked mine and the have these black coated metal tips and I see some kind of black overspray - maybe they made improvements on this year... regardless I cleaned mine and just covered the inside, and inside edges with outdoor high temperature black paint (the ones used for BBQ's).
Post #726004 11th Oct 2025 3:52pm
sullivj
Just check that the water is flowing out of the car as expected by the rear wheel. One of my drains was blocked at the exit point.
Post #726011 11th Oct 2025 5:12pm
