Home > Maintenance & Mods (L405) > Sunroof Drains - Just in time?
Page 1 of 5 12345>
ReggieMac
United Kingdom 2019 Range Rover Autobiography SDV8 Loire Blue
Hi all, have long intended to check the sunroof drains on my 2019 MY. Finally got around to checking them today and was not too surprised to find some rust however on closer inspection I think I may have just gotten lucky and have been able to buy myself some more time by inserting a couple of stainless steel sleeves along with a bit of rust treatment and a healthy dose of WD40.
In the images you can see the 2 drain holes, the sleeve used and also the end result after inserting the sleeves.
 _______________________________________________
2019 4.4 V8 Diesel Range Rover Autobiography, Byron Blue
Post #722227 2nd Aug 2025 6:19pm
Kot
+1 Thanks for the reminder, I really need to check these Whistle 2018 SE SDV8 4.4 Byron Blue
Post #722252 3rd Aug 2025 9:39am
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
I just checked mine—right now, the left one looks worse.
I measured the diameter and it seems to be around 7.5–8 mm. Does that sound accurate to you? Could you also share the length of the one you used?
Lastly, can you tell us where we can get those sleeves?
Thanks a lot!
Post #722256 3rd Aug 2025 11:40am
Looks like I need one (or maybe 2) so just looked them up
https://www.toolstation.com/hep2o-smartsleeve-pipe-support/p29345
Or
https://www.screwfix.com/p/hep2o-smartslee...pack/6398f
I have a mate coming out in a couple of weeks, so asked him to bring some.
Good video here -
Post #722257 3rd Aug 2025 11:51am
adara
Are you sure about the diameter? It looks more like 7.5 - 8mm, not 10... The 10mm diameter seems to be OK for complete replacement, not for inserting in the already existing pipe.
Post #722258 3rd Aug 2025 11:53am
I just took it from the video I linked to - it's in the description on YouTube - I haven't actually measured Embarassed
Post #722259 3rd Aug 2025 11:57am
ReggieMac
This is what I used, event though these are sold out there are plenty other types that do the same job. Dimensions are in the attached image. They were an absolutely lovely fit and pushed in quite easily with a little effort. They do sit slightly proud of the original but as you can see from the first images they drain perfectly well.
https://www.ebay.co.uk/itm/256388938203
also available from here and probably any good hardware store, ToolStation etc.
https://www.ebay.co.uk/itm/388377240993?_t...1506.m1851
Post #722270 3rd Aug 2025 4:18pm
adara
Thank you so much for the details. I was able to find a seller on eBay based in the UK but who ships to Europe. It seems this product is either unavailable elsewhere, goes by a different name, or I'm just having trouble locating it.
Post #722279 3rd Aug 2025 7:09pm
RRYorks
United Kingdom 2018 Range Rover SVAutobiography SDV8 Loire Blue
I agree with you, no way will 10mm go in, 7.5mm drill was the largest I could use. Mine is 2018 model, perhaps they use a thicker tube on later models? 2018 4.4 TDV8
Post #722301 4th Aug 2025 4:25pm
If you look at the diagram a couple of posts up, you'll see that despite being referred to as 10mm, they are actually narrower.
They are inserts to go inside a pipe that has an outside diameter of 10mm.
Post #722304 4th Aug 2025 4:39pm
Rob99
Those inserts are to fit inside Hep2o pipe which has an internal diameter of 6.7mm 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #722305 4th Aug 2025 4:50pm
Extol
United Kingdom 2016 Range Rover Autobiography SDV8 Carpathian Grey
I did do this couple of months ago, bought the 10mm stainless inserts from Toolstation, and used some 3M epoxy glue to fit them in. it fits perfectly. It is very easy to clean now with small pipe cleaner.
My advise is to do this before it starts to rust. I think this is in the Wiki.
mine is a late 2016.
Post #722316 4th Aug 2025 7:32pm
tark
Poland
Sorry for a possibly dumb question, but I thought the whole drain pipe can disintegrate. Is it not so? Does this insert help cause only "intake" is affected by rust?
Can someone describe in layman terms why fitting this insert is enough?
Thanks!
Post #722365 5th Aug 2025 4:41pm
The video I linked above should explain it.
The weak point is where the steel tube / pipe meets the tray, so that's where the insert is used.
Immediately under the tray is a rubber pipe that runs down to the rear wheel arch. So the insert ends up inside the steel pipe inside the rubber tube.
If it's already broken off / crumbled away, then a jubilee clip should attach the rubber hose directly to the insert.
The issue is when the rubber hose becomes disconnected - then any water from the sunroof just drains straight into the headlining and down to the interior floor - then finds its way into various bits of electronics like amplifiers under the seats.
I haven't actually tried yet as my inserts haven't arrived, but I have watched a few videos in preparation.....
Post #722370 5th Aug 2025 5:17pm
tark
Poland
Actually thought metal tubes go much deeper, now it makes sense.
Thank you very much! Ordered the inserts, waiting for the car to come back from service (where else would 405s spend their time Smile), dying to check those holes)
Post #722373 5th Aug 2025 5:37pm
Page 1 of 5 12345>
