![]() | Home > Maintenance & Mods (L405) > Cleaning steering buttons success |
tj196443 Member Since: 08 Oct 2018 Location: Newcastle Posts: 190 ![]() ![]() ![]() |
I decided to try 99% rubbing alcohol of the steering wheel buttons as they were really gummed up and looks terrible, also they were really sticky to touch. Just used some rubbbing alcohol and very happy with the outcome. Here are some before and after photos, took about ten minutes rubbing but worth it.
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 603 ![]() ![]() ![]() |
had to do the same thing works a treat that stuff L405 2014 Loire blue Autobiography |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1557 ![]() ![]() |
Mine are going the same way. Need to try that. V8 or else ... |
I nearly bought a used pair for £65 but glad I didn’t , they take a bit of elbow grease but can be done in about ten minutes and the results are worth it. I’m going to seal them with some interior cleaner so they don’t get gummed up again. |
That looks very neat Gary and more modern than the originals fitted to the earlier cars. I was tempted to go down that route too but cleaning was easier than swapping out, I may still buy a set in the future though. Did you find them easy to install ? |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1493 ![]() ![]() |
Yes? Easy enough. They took about 30 minutes to do. 2015 Range Rover Autobiography 4.4 SDV8 |
goldeneye32 Member Since: 10 Jan 2024 Location: Hampshire Posts: 106 ![]() ![]() ![]() |
