Home > In Car Electronics (L322) > DAB radio module
Page 3 of 3 <123
barbel jim
Different types of dab…… they introduced dab+ to enable more channels. The l322 unit only supports dab, hence why people change the dab module to the latter version. You can stream via Bluetooth and you phone, but still need data and an app. Swapping the dab module to dab+ is simple and probably £120 all in. It has its quirks turning on and off, but you can get alot more chanels, and everything else works as it should
Post #725574 3rd Oct 2025 10:56pm
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Many thanks, I'll look into that idea.
Cheers, Andy Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #725580 4th Oct 2025 8:25am
Jimnic007
United Kingdom 2012 Range Rover Vogue TDV8 Nara Bronze
Hi Jonny,
Do you need to do this every time you want to select DAB+ or just after the first time of installing?
Thanks,
JonnyCJ wrote:
ashtrucker wrote:
Didn’t think you could add DAB+ to l322
You can - with an adapter cable. The only thing you need to do to get it to function is to select DAB on the head unit, switch the display off then on and then turn the volume knob. I did it on my old L320 and it worked fine and lots of other L320 owners have done the same.
Post #726154 14th Oct 2025 4:23pm
barbel jim
From my experience every time you go back to dab +…..
Something to do with the software compatibility, but totally worth it imo
Post #726161 14th Oct 2025 7:07pm
Page 3 of 3 <123
