Home > Technical (L322) > Please help me! 2012 Westminster
Fla
Ireland 2012 Range Rover Westminster 4.4 V8 Zambezi Silver
Hi Ryan
I have a 12 Westie and I also have a whirring noise which is really annoying me also. Even though the car is getting on, has 135k miles on it she has been extremely reliable for me and especially as she is not my daily. You have done huge work on this issue so hats off to you.
I'm convinced mine is coming from the front left so I have bought new wheel bearings but havent installed yet.
Did you ever get to the bottom of your issue or did you just by ear muffs? Current yokes
2012 4.4 TDV8 Westminster
Subaru Sambar Pickup Tipper
2006 Disco 3
Scoobie GT wagon
Mx5 G Ltd
TT S Line
Pajero JDM Exceed
Post #725877 8th Oct 2025 9:12pm
TPLOM
Azerbaijan 2008 Range Rover Supercharged 4.2 SC V8 Epsom Green
Hi RyanC,
did you get anywhere with the road speed related whine from the front left?
I have exactly the same symptoms but not located the issue yet. Have changed the rear prop shaft support bearing to no avail. About to change front left wheel bearing in hope.
Post #726261 16th Oct 2025 1:16pm
Fla
TPLOM
I also have wheel bearings to go in, Im going to do all 4 as Im up to 225km now so why not and while Im in there Ill do discs and pads all round and free up one sticky caliper. Im not convinced its bearings yet but as I say at this mileage its work doing.
Hopefully original poster will come back with an incredibly easy fix! Current yokes
2006 Disco 3
Scoobie GT wagon
Mx5 G Ltd
TT S Line
Pajero JDM Exceed
Post #726307 17th Oct 2025 8:57am
Pug
United Kingdom 2006 Range Rover Vogue Td6 Buckingham Blue
As a thought, could the propshaft have caused damage to the input shaft/seal/bearing on the rear diff?
Even the output shaft on the transfer box?
If it only happens when the wheels are turning, this could be a viable situation.
Not a RR but have had this on a Lada Niva where the UJs on the propahaft weren't acting on the same axis. This caused vibration that wiped out the input shaft bearing on rear diff.
Post #726471 19th Oct 2025 7:13pm
