![]() | Home > Maintenance & Mods (L405) > No heat |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1558 ![]() ![]() |
not sure whether a 5.0 petrol has a fuel burning heater ( and thus no diverter valve ? )
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2294 ![]() ![]() ![]() |
It defo has one as i have the remote for it and can see the gear under the bonnet Current stable:
Ok - so, does the engine get up to full temp ? V8 or else ... |
It does indeed Current stable:
Bardley Member Since: 01 Jan 2025 Location: Hertfordshire Posts: 57 ![]() ![]() ![]() |
This sounds like a blend motor/flap getting lazy.
JMKRR405 Member Since: 08 Oct 2025 Location: Houston Posts: 2 ![]() ![]() ![]() |
Jack - 2014 L405 Range Rover SC V6 Luxor metallic
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1494 ![]() ![]() |
If you are getting *no* heat, it's most likely the FBH diverter valve or electric water pump.
.. 2015 Range Rover Autobiography 4.4 SDV8 |
Thanks gary - I’ve got another diverter although unbranded i think i will just swap the solenoids provided they fit.
If you read the forum, people warn against the cheap diverter valves - people have had issues with them failing. The Bosch one is around £100, genuine £200.
Tbh I did read them and some of the newer comments say you can free the old solenoid off as it’s full of crap. That is the plan a - the plan b is to put the solenoid from the cheap one in it with some rtv as the negativity i’ve seen towards the cheap ones stems from a weep coolant unless youve seen anything else?
So on my fbh woes… the fbh has been on for 5 mins and in the canine it’s blowing from the windscreen vents luke warm at best… could it still be a diverter issue? As said engine gets to temperature fine. Pr could it be the elctric pump and diverter? Current stable:
So today I let fbh run for 25 mins still luke warm, interestingly when I started the car it was stone cold on the gauge - took 5 mins to warm as if the fbh hadn’t been on - but it had been as I could smell it and hear it and the orange light was flashing on climate panel… why are the odds of the electric pump and diverter failing would this cause my issues?
