Home > Maintenance & Mods (L405) > Preventative Maintenance Tip For £2.76
sullivj
United Kingdom 2014 Range Rover Autobiography SDV8 Santorini Black
Electric windows that drag (mainly through lack of use) can cause actuator failure, which is around £400 per door to fix at the dealer!!
Get yourself a can of silicon spray, lower all of the windows and spray it into the window guide channels. Do the same with the sunroof and you’ll be amazed how quickly they open and close again.
https://amzn.eu/d/4rdp2lH
Prevention is always better than the cure!
Post #726072 13th Oct 2025 12:09am
GraemeS
Australia
My previous source of silicone spray now only stocks silicone oil. I used a couple of drops on a house door key a few days ago but oil doesn't have overspray so a few drops here and there in the window runners might also work well. L405 D350 SE Carpathian Grey D5 19" rims
Post #726073 13th Oct 2025 1:39am
Tiny Timmy
Thanks Im going to give it a go , mine are very slow Sad Like you say not used enough Rolling Eyes
Post #726079 13th Oct 2025 10:48am
MR GLOVER
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Thumbs Up my toyota hiace are as slow as f@;k
Post #726104 13th Oct 2025 8:00pm
Tiny Timmy
Re: Preventative Maintenance Tip For £2.76
Just got this and it worked a treat Thumbs Up
Post #726295 17th Oct 2025 6:49am
sullivj
Pleased it worked out for you Timmy Thumbs Up
Post #726297 17th Oct 2025 7:21am
Ffos-y-ffin
Wales 2019 Range Rover Autobiography SDV6 Silicon Silver
Silicon spray can also be used on door seals and anything plastic or rubber to good effect. Great results from spraying the rubber cups that hold the engine plastic covers to the top of the engine. Spray sparingly once a year and the cover will pop on and off as if made of butter. Any squeaks from hard plastic trim rubbing is also eliminated after a squirt and a day or so for the spray to dry and be at its most effective.
I got my last tin of it from the middle of Lidl where they sell the Parkside brand
Post #726402 18th Oct 2025 7:10pm
sullivj
Great tips Ffos
Post #726414 18th Oct 2025 9:58pm
Danwilderspin
I have a very slow sunroof —- same cure? Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #726465 19th Oct 2025 5:56pm
Ffos-y-ffin
While my sunroof was working normally, I did spray the seals and workings as best I could. At the very least the silicon will keep the rubber in good condition for longer and reduce friction when the panel starts opening.
Try it on yours to see if it helps.
Post #726479 19th Oct 2025 8:43pm
