![]() | Home > Technical (L322) > DPF sensor readings |
| Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3883
The only way to clear the limp mode red DPF is to do a Forced Regeneration .
| SpitfireS Member Since: 10 Jun 2019 Location: Mainz Posts: 129
Mine reads 0.73x volt, engine not running.
| claeszv Member Since: 07 Aug 2025 Location: Copenhagen Posts: 9
Thanks a lot. The measures i was looking for |
Tried to do the regen many times. Iidgaptool says "regenerating" but sootlevel just continue rising. I also tried with "fit new particulate filter" and offcourse cleared DTC's I guess some readings are not right, since its not regenerating |
| pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 1031
do you have half tank of diesel fuel ?
Big mistake trying the fit new DPF , sorry but your iid now thinks your DPF is new with zero soot , 0g, so it won’t initiate a forced regen until it thinks its full, or at least above 20+g.
3/4 of diesel, but workshop manual says 1/4 Drove motorway for about an hour. |
I did a DPF clean my self, injecting cleaner in the pressure tube and followed the instructions incl. reset. I did wait until soot level was 20grams before starting the cleaning proces, and i dont know if it actually started the regenerating process, because you cant see the DPF temperatures in IIDtool when running the process. Would be nice though I ended up taking the DPF for a specialist. He cleaned out the ash and cars running again |
| All times are GMT |
