Home > Technical (L322) > looking for coolant hose connector 2012 TDV8 4.4
Folkert
France 2012 Range Rover Vogue TDV8 Baltic Blue
Hi All, I have a MY2012 TDV8 4.4 and while disassembling the donut to be able to replace the oilcooler i pulled the little coolant hose that is connected with a small bracket to the donut. the plastic elbow connector was all brittle and the lower part where the rubber hose slides on just snapped off. Also the rubber ring where the connector is mounted with fell somewhere down below during the incident.
Embarassed
Question: is this a generic part and if so what is this oficially called? or should i just source the LR one by part number? if so... what is the partnumber for this plastic elbow connector?
see pics
Thanks in advance, Folkert
 2012 L322 4.4 TDV8 VOGUE
Baltic Blue, Parchment interior,
Suede Ceiling, Rear Entertainment,
Front Seat Cooling, Tow Kit.
Post #726253 16th Oct 2025 8:33am
kevinp
I think it is part of LR022690. Just done my cooler and replaced all the hoses and connectors possible. Quite a few of the connectors broke on mine with very little force.
Post #726254 16th Oct 2025 9:15am
Folkert
Cheers!!! I indeed see it is part of the top radiator hose kit. i think for now i will just find a universal quick release elbow connector in the correct size. i think i read somewhere 9.98mm is the correct one.
Will give an update. 2012 L322 4.4 TDV8 VOGUE
Post #726256 16th Oct 2025 9:45am
Folkert
Just ordered this elbow quick connector on amazon, i think that should do it, will let you know when in and installed. 2012 L322 4.4 TDV8 VOGUE
Post #726406 18th Oct 2025 8:37pm
Folkert
Just an update: received the connector and installed it. The new male connector slides and clicks perfectly in the original LR female part. So i ended up using both.
Mission accomplished! Or not.. huuuhhh:
The connector on the other side of the same rubber tube also broke off!!!! Oh 🫨 noooooo!!
I was hoping to put it all back together today but will have to source the other part first. It doesnt look as generic as the connector above, so i guess i have to get a genuine LR one.
Anybody who can help me further with part nr?
See pics below.
Post #726634 22nd Oct 2025 3:18pm
Folkert
Found it! Is part of the water outlet hose. LR022690
Post #726637 22nd Oct 2025 4:59pm
