Home > Technical (L322) > TPS position error
claeszv
Denmark 2011 Range Rover Vogue SE TDV8 Santorini Black
TPS position error
Hi
I have theese error live values from IIdtool. What does it mean?
Car is running perfect and no fault codes.
Problem is that DPF soot level is full after only 50 km. Had the DPF tested and cleaned by specialist and its like new.
I have done a DPF reset an a relearn DPF sensor as described in the WM, but the soot level never comes under 8g after regeneration.
i will do a smoke pressure test tomorrow.
2 new turbos installed
What do you think?
L322 4.4TDV8, 270.000km
Post #726803 24th Oct 2025 7:28pm
JayGee
AFAIK 100% means no error. Was the DPF removed from the vehicle and backflushed to remove the ash? 2012 TDV8 Vogue (L322)
Post #726814 25th Oct 2025 10:08am
claeszv
Thanks for your reply.
Good to know 100% means no error allthough its a bit confusing.
Yes the DPF was removed and backflushed profesionally and with testreport saying 19mb. As good as new
Post #726816 25th Oct 2025 10:17am
